Results 1 to 10 of 11
Thread: Clutch - Getting into Gear
    Apr 2008
    Limerick
    Default Clutch - Getting into Gear
    The last few mornings, I have been having terrible trouble getting into gear, I know the 'C' hasnít got the silkiest gear box, but Jesus, I nearly have to hang out of the gear handle to select gears. The problem seems to gradually sort itself out on the 30 min drive to work. I don't know if itís the clutch, gearbox or just the weather!!
    glasgow
    Quote Originally Posted by patsy111 View Post
    sounds like you need to get your clutch slave cylinder bled + check brake fluid level as it feeds clutch too the fluid works better when it gets hotter thats why on the trip it gets better,prob just needs bled
    Apr 2008
    Limerick
    Thanks alexgrfc, sound like some good Info - I have a fair idea what is required to be done, but if you had any more information it would be great. (Exact Locations, types of equipment - thanks).
    Rgds Pat.
    glasgow
    the slave cylinder is at the top of the gearbox isnt that hard to get to the bleed nipple ,you can buy a self bleeding kit from halfords and follow the instructions or do it the old way with a piece of hose and a bottle then have someone pump the clutch pedal till the air gets out
    Apr 2008
    Limerick
    Just wondering alexgrfc, if you have this problem youself? Does the 'C' give this sort of trouble often?
    Thanks again.
    Rgds Pat
    glasgow
    Thanks again.
    Rgds Pat
    yup i have a 52 plate ellegence and had the same problem ,it gets worse in the winter so best get it done its an easy fix
    Regular Member mattolly86's Avatar
    oxfordshire
    this is what all theads should be like good going guys
    Apr 2008
    Limerick
    Thanks again alexgrfc, looks like I know what I'll be doing with my hangover on Sunday AM!!
    P.S.- To the lads that run this forum, great work, has saved me a few times in the past and looks to have done so again!!
    glasgow
    np love to try and help
    Regular Member jillydabrat's Avatar
    Apr 2009
    Teesside
    Default thank gawld it's not me going crazy then
    We bought Victoria in April, within days we contacted the garage about the catching of the gears between 2nd and 3rd when the engine was cold.
    When we finally managed to secure a courtesy car they took it in and decided it was the flywheel!
    Flywheel replaced.
    Picked up car, absolutely no different than when we took it in.
    We read this post and when we took the car back in yesterday we told them what had been posted here. Have they sorted it...............NO So we are going to print the responses off and take it to them to see if they can comprehend it in writing
  1. Reverse gear problem after new clutch!
    By daniel9807 in forum Vectra C / Signum Car Chat
    Last Post: 29th September 2012, 12:41
  2. Clutch/Gear Selection problem
    By Thom in forum Engine & Drivetrain
    Last Post: 28th July 2012, 21:08
  3. 1.9cdti clutch worrie m32 gear box
    By 0114NIGEL0114 in forum Engine & Drivetrain
    Last Post: 5th May 2011, 21:48
  4. Clutch in...have to be hercules to put in gear!
    By wingz123 in forum Vectra C / Signum Troubleshooting
    Last Post: 27th March 2011, 11:14
  5. Clutch in...have to be hercules to put in gear!
    By wingz123 in forum Engine & Drivetrain
    Last Post: 27th March 2011, 00:42
