Results 1 to 3 of 3
Thread: Strange hose near airbox - should it be connected
    Leicestershire
    Default Strange hose near airbox - should it be connected
    Had a look under the bonnet to see if I can suss out why the veccy isnt quite right - see other post
    http://www.vectra-c.com/forum/showthread.php?t=83712
    I have spotted a hose that isnt connected at one end. The hose is down between the radiator and the airbox, it is around 3/4" diameter and underneath a larger hose. The other end of the hose seem to go into the bottom of the airbox.
    Is this a breather pipe or should it be connected?
    Here is a photo (not very clear I know) its the black hose sort of in the middle of the photo
    Any help would be gladly received.
    Leicestershire
    Morning All....
    Was going to have more of a look at the weekend but got washed out
    Any pointers from anyone?
    Thanks,
    markluk
    stockport
    Arrow "Spare hose"(1.9CDTI 150).
    Hi.I found the same pipe this weekend when I removed the air box to fit a missing section of pipe ducting that fitted to the intake scoop.
    There's a hole near the bottom side of the outside of the air box which this hose seems to connect with,and a notch in which it located with and was a ***** to get in. I used a fat headed screwdriver and fairy liquid.That sorted it. ("Get in").
    When it's located in the air box,because of its position and the way it shapes round and down,its then in position to connect naturally to some sort of breathing pipe coming up from the bottom of the engine.(The pipe that I found in my engine bay has a small stub/branch piece which is blanked off).I am pretty sure its the same type of hose.Hope this helps.Felixx.
  1. Air inlet hose size (airbox)
    By cont1204 in forum Vectra C / Signum Car Chat
    Last Post: 12th December 2012, 19:30
  2. Rubber hose on the underside of the airbox ?
    By VecPower in forum Engine & Drivetrain
    Last Post: 3rd February 2012, 13:56
  3. CDTi 150 Airbox hose?
    By RobW in forum Engine & Drivetrain
    Last Post: 23rd January 2011, 16:46
  4. 3.2 GSi airbox hose diameter
    By Tennants in forum Vectra C / Signum Car Chat
    Last Post: 21st March 2010, 20:53
  5. airbox hose
    By 19CDTi in forum Vectra C / Signum Car Chat
    Last Post: 8th January 2010, 23:56
what is the pipe conected to the bottom of the airbox vectra c
