Results 1 to 10 of 23
Thread: Oil what type
    Regular Member willoftoon's Avatar
    FOREST HALL NEWCASTLE ,,,,,OR DECKHAM ,, ON SUNDAYS .. DINNER TIME MAMMY,S
    Default Oil what type
    what do i use in me 1.9 cdti is it semi synth or other jut i have got filters for lads at work to service it we have oil for trucks and semi synth for new trucks good oil will this be ok to hoy in what is the ratio needed for diesel oil
    Regular Member barkzz's Avatar
    Quote Originally Posted by willoftoon View Post
    If it were me id be putting 0w30 fully synthetic in.
    Vauxhall will usually put 5w30 fully synthetic "long life GM" stuff.
    That's what allows for the more flexible longer service intervals.
    If you want this use theres, if you quite a keen oil changer go with the 0W30 Fully synthetic
    Full Member Big Sig's Avatar
    you can use 10/40 if you don't have a dpf and do less than 10k between changes.
    what's a dpf also was thinking about castrol or the like if I buy me own
    DPF Diesel particulate filter. Have a search. If you have one be a bit more careful what oil you use.
    What car do you have?
    Carmarthen
    Vehicle : Insignia
    Trim : Sri
    Engine : 140 Ecoflex S/S
    1.9 CDTi
    I that 1, 150 type
    just did a search on dpf still stumped something about since 2009 mine is a 54 plate we have semi synth 10/40 at work I will try to find book on car I misplaced it and look in there
    Will, from the link I posted previously
    http://www.vauxhall.co.uk/vaux/owner...do?method=view
    All Vectra-C's from 2002 onwards should use 5w/30 fully synth.
  1. Oil type n how much
    By mrpoochie01 in forum Vectra C / Signum Car Chat
    Last Post: 14th March 2012, 02:06
  2. 3.2 oil type
    By Chuddy in forum Engine & Drivetrain
    Last Post: 6th September 2010, 19:38
  3. VXR type-R & type-S
    By Craig1985 in forum Vectra C / Signum Car Chat
    Last Post: 14th May 2009, 21:16
  4. 3.2 V6 Oil - What type?
    By aaruck in forum Engine & Drivetrain
    Last Post: 7th June 2008, 20:42
  5. Type PSI
    By TheWildHaggis in forum Vectra C / Signum Car Chat
    Last Post: 22nd March 2008, 16:19
