Page 1 of 7 123 ... LastLast
Results 1 to 10 of 68
Thread: Geek needed !
    Regular Member Lump's Avatar
    coventry
    Default Geek needed !
    ok guys trying to set up a home network for our business. i have one laptop running XP wireless. and a PC running through ether net cable from the wireless router. so how do i connect them. i have tried. but my knowledge is limited so if any one can help
    Edinburgh
    are neither working? I would expect the one connected via ethernet to pretty much be plug and play.
    Are you trying to get out on the 'net from it or get the two PCs talking to each other to share files etc?
    coventry
    nope cant get either to even see the other, and it has to be done via Internet connection. bought a cable off ebay but the driver is useless
    Edinburgh
    ok is the wireless one showing as at least connected to the wireless network? if so, do both PCs have an IP address issued to them?
    coventry
    the PC is plugged in to the router and does not use wireless, the laptop is wireless. and have no idea about IP
    Edinburgh
    ok so the wireless laptop, have you managed to connect it to the wireless network yet?
    To find out if the PC or laptop has an IP, click on START, and then RUN. type in "cmd" (without quotes)
    Once you have the black command prompt box up type "ipconfig" (again without quotes). You should then see a whole bunch of details. Look for the IP address one. Is it something like 192.168.0.2 or 10.0.0.5? if so great. if it's 0.0.0.0 or 169.254.x.x that's not so great.
    coventry
    the laptop is already connected and we have two different IPs
    Regular Member lofty's Avatar
    @home
    Vehicle : Vectra C Estate
    Engine : 1.9 CDTi
    click on START, and then RUN. type in cmd
    In the dos box type PING (then put in the IP address of the other machine)
    If you get a reply then you have connectivity.
    What is it you want to do btw?
    Do you want to share files/folders? If so you'll need to setup file sharing.
    coventry
    Quote Originally Posted by lofty View Post
    did that, no connection, and yes its so i can work on documents on the PC
    Edinburgh
    can either machine connect to internet?
  1. Turning into geek
    By eve01rton in forum Vectra C / Signum Car Chat
    Last Post: 13th January 2013, 10:46
  2. hmmmmmm are you a car geek?
    By hoochydady in forum General Chat
    Last Post: 12th May 2011, 21:28
  3. Geek Needed
    By Lump in forum Photoshop section
    Last Post: 18th May 2009, 22:36
  4. Geek needed
    By Lump in forum The 'Off Topic' room
    Last Post: 4th January 2009, 21:09
  5. Geek
    By edition100 in forum Comedy & Humour
    Last Post: 19th August 2005, 23:53
