Results 1 to 10 of 14
Thread: corsa vxr wheels
    Regular Member andy76's Avatar
    sheffield
    Vehicle : cdti 150
    Trim : sri
    Engine : z19dth
    Default corsa vxr wheels
    will they fit strait on with 5mm spacers.
    also they come with 225/35/18 tyres but im sure i read somewere that there no good for the vec, is this true.
    dont want to bid on any if i have to get new tyres.
    Regular Member glynn's Avatar
    stevenage, hertfordshire
    ive seen them on a black veccy b 3.2 v6 and they look very sweet indeed
    Leicester
    If you fit them with 5mm spacers, you will be about right with the offset, so no problems there.
    But 225 35 18" tyres are useless on the Vectra C, they are too small in diameter.
    Regular Member danBoy's Avatar
    Jun 2006
    Northampton
    This Vectra has Corsa VXR wheels on
    http://www.vectra-c.com/forum/showthread.php?t=83103
    Regular Member Robbie69's Avatar
    PM swainy he's just done it and I don't thin he needed spacers.
    Regular Member bobby-tupper's Avatar
    LEEDS, W.YORKS
    Vehicle : 07 Estate
    Quote Originally Posted by Robbie69 View Post
    sheffield
    Vehicle : cdti 150
    Trim : sri
    Engine : z19dth
    cheers, what tyres do i need with 18's ( it will be lowerd one day aswell)
    Regular Member robk6112's Avatar
    Halifax
    225/45w18 is the correct size
    Full Member spennny's Avatar
    Blantyre
    You watching the ones on ebay
    Leicester
    Yes you don't actually need the spacers to make them fit, but the Corsa VXR offset is wrong for Vectra C. The 5mm spacers will raise the offset to the correct distance.
    A) They look wrong on Vectra C with ET47-ET49
    B) The handling won't be right as GM don't fit ET47-49 offset wheels to Vectra
    Tyre wise, as said, 225 45 18" is the correct size for Vectra C, you can't really use the 235 40 18" tyre like the VXR as the VXR 18" wheel is 8" and not 7.5" like the Corsa's.
    225 40 18" would be the best compromise, these tyres were offered by Opel in Europe so you will be fine.
  1. Corsa VXR wheels
    By the_wave_rider in forum Suspension, Wheels & Brakes
    Last Post: 16th February 2011, 18:45
  2. Corsa VXR wheels
    By julian924s in forum Vectra C / Signum Car Chat
    Last Post: 17th February 2009, 23:01
  3. corsa vxr wheels
    By swainey in forum Vectra C / Signum Car Chat
    Last Post: 24th November 2008, 22:59
