Results 1 to 3 of 3
Thread: Lumpy tick over and no low end power - Help
    Leicestershire
    Default Lumpy tick over and no low end power - Help
    Help - idiots guide required!
    I had the fun recently of driving 140 miles in limp home mode after a holiday and the problem seems to have cured by a new EGR valve.
    The veccy is now playing up again 3 days after the new EGR with slightlyu lumpy tick over and no umph below 2000 - 2500 revs.
    I have had the annoying spanner light flash up on start up for a while and this has come back since the EGR valve - ppl on here advised me that it may be a split hose.
    I dont want to take it back to the stealers to sort it but I am fed up with the poor low end performance - mpg is all ok and generally the car is ok.
    If anyone have for tips or an idiots guide to hose checking I would appreciate it.
    Thanks....markluk
    Regular Member keithsimmo's Avatar
    in the engine compartment.
    Taking out and gentally cleaning the boost sensor could help?
    Check all your hoses for splits?
    Take back to the stealers and tell them the Replacement EGR valves didnt resolve the problem and you would like your old one fitted back on and a full refund.....?
    Leicestershire
    Thanks for the reply.
    I might take a look at the boost sensor again - I did clean this a few weks ago but I did have the 140 mile run in limp home mode recently which may have choked it up again.
    The new EGR did cure the problem - the car died on any slope - thought I was going to be stuck on my sloping drive when I took it to the garage.
    My gut feel in a split hose but I cant see anything - where are the pipes??
    Please help I dont like driving a gutless veccy!
    markluk
  1. No power & very lumpy running 1.9 cdti
    By phil147 in forum Engine & Drivetrain
    Last Post: 19th June 2013, 17:25
  2. smoke, loss of power, lumpy, cut out, help please.
    By GrannySmiff in forum Vectra C / Signum Car Chat
    Last Post: 17th April 2012, 07:06
  3. black smoke both at tick over and under power
    By aidy-cdti in forum Engine & Drivetrain
    Last Post: 23rd July 2011, 14:39
  4. cdti running really lumpy and no power??
    By richiem in forum Engine & Drivetrain
    Last Post: 7th July 2010, 19:16
  5. Tick over 2500 rpm and loss of power
    By Swanni in forum Engine & Drivetrain
    Last Post: 27th March 2009, 08:00
