Thread: V6 CDTI axle \spring weight?
    Regular Member Ziggy's Avatar
    Leeds
    Vehicle : Saab
    Trim : 9-3 Vert
    Engine : 2.0
    Year : 2000
    Default V6 CDTI axle \spring weight?
    Can anyone confirm the above for me please?
    Thank you inadvance
    Stephen
    P.s I know its on my car but my car isnt with me and i forgot to check last night
    Regular Member zazaszazas's Avatar
    Cumbria
    Vectra 3.0 V6 CDTI 130kW/177hp 6-speed sports sedan Model year: 2005 ½
    Date: 01/2005
    Engine data
    Engine: 3.0 V6 CDTI ECOTEC
    Engine, location: front, transverse in front of axle, 1° forward inclined
    Cooling system: with liquid, sealed circuit
    Cylinders, number: 6
    Bore (mm): 87.5
    Stroke (mm): 82
    Displacement (cc): 2958
    Compression ratio: 18.5:1
    Engine, type: V 66°; 4 main bearings
    Cylinder block/head, material: aluminum/aluminum
    Camshaft(s), location: 4 overhead (DOHC), gear/toothed belt
    Valve train: direct, bucket tappets
    Valve, arrangement: parallel; 4 per cylinder
    Valve adjustment: mechanical
    Fuel system: diesel direct injection, common rail
    Fuel pump: high pressure, mechanic
    Emission control system: 2-way cat. conv. (oxidizing catalytic
    converter), exhaust gas recirculation
    Charger system: turbo with intercooler
    Max. boost pressure (bar): 1.2
    Output (kW/hp CEE at 1/min): 130/177 at 4000
    Specific power (kW/l; hp/l): 43.9; 59.8
    Max. torque (Nm at 1/min): 370 at 1900
    Specific torque (Nm/liter): 125.1
    Mean effective pressure at
    max. power/max. torque (kPa): 1318.5/1572.6
    Average piston speed (m/s): 10.9
    Engine oil, capacity (l): 7.25
    Cooling capacity (l): 8.3
    Battery 12 V, capacity (Ah): 85
    Alternator 14.2 V, capacity (W): 1988
    Transmission
    Drive axle: front wheel drive
    Transmission, type: 6-speed manual
    Gear ratios: 1st ratio: 3.77 2nd ratio: 2.04 3rd ratio: 1.32
    4th ratio: 0.95 5th ratio: 0.76 6th ratio: 0 .62
    reverse ratio: 3.54 final drive ratio: 3.55
    Clutch, type: dry single plate
    Body
    Seats: 5
    Drag coefficient (cD ): 0.28+
    Frontal area (A in m²): 2.18
    Index (c WxA): 0.61+
    IDSPLUS chassis
    Wheel suspension front: independent, McPherson struts, wishbone, on subframe,
    gas pre-loaded struts with continuous damping control (CDC)
    Wheel suspension rear: multi-link suspension, 3 transverse+1longitudinal arm,
    coil springs, gas-filled shock absorbers with CDC
    Anti roll bar: front + rear
    Brakes
    Brake circuits: 2, diagonal
    Brakes front, diameter (mm): ventilated disc, 314
    Brakes rear, diameter (mm): ventilated disc, 292
    ABS: standard equipment
    TC Plus: standard equipment
    ESP Plus: standard equipment
    Weights and dimensions
    Length (mm): 4596
    Width (mm): 1798
    Height (mm): 1460
    Wheelbase (mm): 2700
    Track front/rear (mm): 1536/1525
    Luggage capacity (l) ECIE: 500-1360
    Opening luggage compartment to ground (mm): 703
    Rim width (inch)(mm)/tire size: 6,5Jx16/215/55 R16 V
    Turning clearance circle/turning circle (m): 11.55/10.81
    Steer. wheel turns lock/lock: 2.75
    Steering, ratio: electr.-hydr. power steering, 15.2
    Steering wheel outside diameter (mm): 385
    Kerb weight/max. allowable weight/additional load (kg): 1650/2125/475
    Power to weight ratio (kg/kW; kg/hp)(empty): 12.7; 9.3
    Max. axle load front/rear (kg): 1160/980
    Trailer load braked/unbraked (kg): 1600/750
    Trailer hook weight/roof load (kg): 78/100
    Fuel tank capacity (l), location: 61, under rear seats
    Performance
    Top speed (km/h)* : 226
    Acceleration 0-100 km/h (sec)* : 9.3
    Acc. 80-120 km/h in 5th gear (sec)* : 8.4
    Pass-by noise (dBA): 73
    Fuel: Diesel
    Fuel consumption (liter/100 km): Measured according to EU guideline 99/100/EU.
    Additional equipment can lead to increased
    consumption and CO2 values.
    urban: 9.9 - 10.0
    extra-urban: 5.5 - 5.6
    total: 7.1 - 7.2
    CO2 emission (g/km): 192 - 194
    Emission class: Euro 3
    Maintenance
    Service intervals: Service check every 24 months or after up to 50,000 km
    + Basic model
    * Kerb weight (70156 EEC) and 125 kg payload
    Hope this helps
    Full Member Big Sig's Avatar
    Hunt the smilies
    Leeds
    Vehicle : Saab
    Trim : 9-3 Vert
    Engine : 2.0
    Year : 2000
    Thank you very much!!!!!
    Why can't all forums be as helpful !!!!!!!!!!!!
    [Ex]Admin Duncan's Avatar
    Hunt the smilies
    It's in there somewhere!
    Quote Originally Posted by s_zigmond View Post
    'cos they aren't us!
  1. 2.8T V6 Axle Weight
    By parapaul in forum Vectra C / Signum Car Chat
    Last Post: 18th August 2009, 10:23
  2. axle weight
    By chelskilee in forum Handling & Braking
    Last Post: 23rd February 2009, 20:53
  3. Axle weight?
    By Paul_O in forum Suspension, Wheels & Brakes
    Last Post: 13th August 2008, 17:53
  4. 1.9 cdti 150 front axle weight
    By Beavis in forum Vectra C / Signum Car Chat
    Last Post: 25th October 2006, 12:11
  5. axle weight ?
    By JOE DTI in forum Vectra C / Signum Car Chat
    Last Post: 23rd October 2006, 17:41
spring vectra c 1.9cdti 120km
