Results 1 to 10 of 13
Thread: Does my AC need a regas or is it more involved
    Regular Member gumanue's Avatar
    West Yorkshire
    Default Does my AC need a regas or is it more involved
    Hi
    I bought a 56 plate Signum about a month ago with just 18000 miles on the clock. I noticed that there was a hissing noise that got louder and suddenly stopped every few minutes, I soon worked out that this noise was the AC. After frequent use of the AC this hissing seems to only happen on switch on and just now and again whilst driving so I think things are improving, however, the AC is generally quite noisy. Another strange thing is that the drivers far right vent is nice and cold but the vents gradually get warmer as they move towards passengers side but if I close both drivers vents the passenger vents become nice and cold, also the AC struggles when the fan is on high.
    If I assume this is not normal, do you think a regas will sort the problem, or is it more involved.
    I have 12 months networkQ warranty, but I'm not sure if this is covered.
    May 2008
    newcastle
    take it back & complain, i did & got mine re-gassed FOC with the added flourecent dye which was checked at it's next service for leaks.
    West Yorkshire
    Trouble is I bought the car in luton and I live in Wakefield so it will be cheaper to go to kwikfit than pay for the fuel. Did you have the same symptoms and was it fixed with a re-gas?
    Regular Member Hedgehog70's Avatar
    Yorkshire
    It should be covered under warranty - It's not even 3 years old yet, never mind the Network Q warranty
    T
    Sunny Dartmoor
    I'd ring the dealer you bought it off and explain what has happened and get the work done locally or at kwik fit and send the dealer the bill,it worked for me when i bought my veccy,radio needed recoded so got it done locally and sent them a copy of the bill and recieved a cheque in the post,hth.........
    May 2008
    newcastle
    mine just made an annoying whirring noise when i turned it on that kept coming & going, it did wok in a fashion but it was much cooler when re-gassed ( noise dissapeared too.)
    West Yorkshire
    I'll ring them tomorrow.
    I was unsure because it does blow cold just not everywhere. I wondered if vauxhall AC was always like that.
    if its got a network q then any network q garage can look at it, not just the supplying one.
    Regular Member Avenged's Avatar
    Liverpool
    ... didnt think air con re-gas came under warranty?
    the parts for it will! if they are found to be faulty..
    hth
    he said it doesn't need a re gas as he's checked it. So if he is right its parts so should be covered.
  1. Cheap air con regas ?
    By nigec in forum Bodywork & Interior
    Last Post: 26th April 2010, 16:48
  2. Air con regas
    By axelf in forum Engine & Drivetrain
    Last Post: 20th April 2010, 23:37
  3. Air con regas
    By willoftoon in forum North East RO Vacant - ARO - Vacant
    Last Post: 7th July 2009, 20:52
  4. Kwik fit regas
    By lofty in forum Vectra C / Signum Car Chat
    Last Post: 30th May 2009, 21:48
