Results 1 to 10 of 21
Thread: Limp Home Mode - K&N Filter to Blame?
    Northants
    Unhappy Limp Home Mode - K&N Filter to Blame?
    Hi, hoping someone here can help. Last Friday I fitted a K&N panel filter to my 2.0 DTI. Over the weekend I've just been pootling around and the car has been running fine. Last night (Monday) I opened it up on a dual carriageway and when I hit 4K rpm I lost power and the spanner symbol appeared in the display. From here on the car was gutless and wouldn't rev over 3K rpm. This morning the car ran fine and no fault display, later today I decided to give it some welly but as soon as I got up to 4K rpm it went into limp home mode again
    So is it the K&N filter or is this just a coincidence?
    Thanks for any advice...
    South Wales Assistant Regional Organiser davidjameswest's Avatar
    llantwit major
    coincidence i think mate put orig filter and try booting it and see if it still happens
    Regular Member ghostrider's Avatar
    On another planet
    Vehicle : 2.0l CDTi Bi-Turbo Insginia Sports Tourer
    Trim : Vx Line Nav Sri
    Engine : 2.0
    Have you tried disconnecting the battery for 30mins, then reconnecting it?
    The ECU will have to learn the new filter specs etc.
    Northampton
    Hi mate, i have the same problem. its nothin to do with the filter. its the Turbo pipe which goes from the EGR valve to the intercooler which should have a rip or hole in. will need to get this replaced. its a common fault! second time its happened to me. pipe cost around £60
    Northants
    Quote Originally Posted by ghostrider View Post
    Nope haven't done this. Assumed the ecu would compensate automatically??
    Northants
    Quote Originally Posted by Niks View Post
    Sorry to be a noob but what's the EGR valve and where is it??
    Northants
    Not wanting to complicate matters but I also had an oil & filter change done on Monday morning but I can't see that it would have an adverse affect?? Surely even formula 1 autocentre can change a filter & oil without f**king things up??
    Oct 2006
    Waterloo, Liverpool
    10 Post(s)
    Trim : SRI NAV XP
    Engine : 1.9 CDTI 150
    Mileage : 72K
    Quote Originally Posted by davidjameswest View Post
    Vehicle : Signum 2.0 DTi
    Trim : Elegance/Elite
    Engine : 2.0DTi
    Mileage : 73350
    Ok mate first things first check all your vacuum hoses are connected properly , with an air filter change on a dti itr is easy for the vacuum hoses to be pulled and dislodged , make sure the hoses have been put back in the right place , unbeleivable i know but they did it to me . on top of that check the intercooler hoses are tight as well . if you need any more info just ask
    regards bob
    and still loving it
    Northampton
    Quote Originally Posted by AirCooledHeaven View Post
    its right under the engine cover. take it off and its the rubber pipe on the right hand side. the EGR valve is just at the bottom of the engine cover and the pipe coming out from the right
  1. Limp Home mode
    By gary_e in forum Engine & Drivetrain
    Last Post: 28th August 2012, 20:49
  2. Limp Home mode
    By Bredsticz in forum Engine & Drivetrain
    Last Post: 12th July 2012, 19:43
  3. limp home mode
    By FRANKA in forum Vectra C / Signum Troubleshooting
    Last Post: 24th September 2011, 12:04
  4. limp home mode
    By trickster75 in forum Diesel Engine related
    Last Post: 18th July 2010, 16:58
  5. Limp Home Mode
    By dud in forum Engine & Drivetrain
    Last Post: 10th July 2008, 15:06
