Thread: CID connections
    Gloucester
    Default CID connections
    Does anyone know what the connections are an the back of the Siemens VDO CID?
    Mine has two multi pin connectors, the blue one is part of the CAN bus I assume, but the other? And as to what pin does what I don't know.
    I'm tying to fit a parking camera to it, and I've seen one solution that breaks in to the connection to the LCD unit, but I think it could be done better.
    Yours Simon M.
    Regular Member kenp's Avatar
    Kr. Hyllinge, Denmark
    Engine : 2.2 Direct
    The other is for the actuall RGB colours.. that connects to the CD70.
    Surrey
    There are a couple of guys selling interfaces from remote parts of Europe.
    The kit I bought simply takes the original ribbon feed from the controller and it goes into the interface. A new lead plugs into the display. Thus it remains standard until you push a button then it switches to a RCA input, push again and it goes to the 2nd RCA input then again to return to normal CID menu. It has another RCA input to feed a reverse camera and it can automatically switch to this input as you wire it to the 12v reverse signal.
    Gloucester
    Thanks for the replies,
    I have a link to the LCD display but no data on the 'other' connector. Hi Kenp you say that this is an RGB interface, do you have any further info on it?
    Yours Simon M
    Engine : 2.2 Direct
    what do you mean! its just a cable that connects the radio and CID to gether and the otherbit as steve talks about it another bit that can make the CID for some good use.
    Admin plasma's Avatar
    On the Forum
    312 Post(s)
    Engine : 150
    Mileage : 74000
    info coming up
    Plasma's Tech2 services are now partially open and able to provide services
    Come Join our new forum Insignia Owners.com for all your Insignia chat and needs
    On the Forum
    312 Post(s)
    Engine : 150
    Mileage : 74000
    For the RGB connections as follows.
    Pin 1 - Video Sync Low Ref
    Pin 2 - NC
    Pin 3 - Video blue
    Pin 4 - Video RGB Low Ref
    Pin 5 - Video Sync
    Pin 6 - NC
    Pin 7 - Video Green
    Pin 8 - Video Red
    Pin 9 - Video Drain Wire
    Pin 10 - Video Screen
    Surrey
    I converted my CD70 to accept video inputs using a kit. PM me your Email address and I will send you what I have.
    Admin & Merchandise Manager bigmac's Avatar
    Devon
    72 Post(s)
    Vehicle : insignia
    Trim : irmscher
    Quote Originally Posted by steve1975l View Post
    Did he ever get back to you about using the NCDC colour screen Steve ?
    Gloucester
    Hi plasma
    Which end is Pin 1?
    Yours Simon M.
  1. Ecu Connections
    By viper8 in forum Engine & Drivetrain
    Last Post: 20th August 2011, 17:03
  2. What connections...?
    By n_hudson in forum Vectra C / Signum Car Chat
    Last Post: 30th August 2008, 13:33
  3. BSR PPC connections?
    By FiscusFish in forum Diesel Engine related
    Last Post: 30th April 2008, 15:33
  4. ISO connections
    By R13hard in forum Electrical & ICE (including SatNav)
    Last Post: 28th February 2008, 00:21
  5. PS3 Connections?
    By Stevel in forum Games Room
    Last Post: 9th December 2007, 22:57
