Thread: z20net power problem any help or ideas needed
    west yorkshire
    Default z20net power problem any help or ideas needed
    Hi guys
    i have a 2004 53 plate 2.0t now the problem it has is this every so often the engine light comes on and in first and second there is no power at all its only when i get into third ( just ) that the turbo kicks in more and it drives as normal until the next junction, now if i turn it off and on again it will be fine for a few mins or a few days but the light stays on all the time and out the blue the same lack of power again.
    i have had the fault read and it said the mass airflow sensor so i have had that changed and the problem is still there i have also been told its the egr valve but this engine does not have one according to the local stealers
    so if any one has had the same issue or just knows what it might be please let me know
    thanks
    Full Member Big Sig's Avatar
    Who read the fault code? have you tried driving the car with the maf disconnected?
    west yorkshire
    it has been read by one guy who said no power going to it but that has been tested and there is also read by the rac and another garage but not the dealer, i have not tried driving with out it connected but i will go and try it now and see what happens as it was only today that the rac looked at it and cleared the code again so i will post the result in about half an hour
    Regular Member Swaite53's Avatar
    South Wales
    I have a 53 2.0T with similar sounding problems, hope this may help you:
    http://www.vectra-c.com/forum/showth...816#post973816
    EVERYWHERE
    What is the fault code ? Also pretty sure that most engines have EGR valves! ? And the symptoms suggest that as a possible cause.
    Full Member gibbon7000's Avatar
    lincs
    Ive just had my power loss problem sorted on my 2.0T. Turned out to be the accelerator pedal needed changing. The car wasn't regconising that the pedal was been pressed, therefore no power.
    My other car. 1972 1641cc slammed beetle. On the road finally!!
    EVERYWHERE
    Thank God for fault codes!
    west yorkshire
    hi guys firstly thanks for the quick response, i have just been out in it with the mas disconnected and there was no power at all so plugged it back in an it ran fine ( see how long it lasts ) i cannot remember the fault code exactly but it was something like p1019 or there abouts but it says it was the mas, i will investigate the other suggestions from you all over the next few days and keep you posted
    thanks again guys
    If it ran fine with it plugged in and badly with it unplugged it sounds like its working, or at least was when you tried it. Did the rac write the code down on a job sheet like the AA do?
    [Ex]Admin Duncan's Avatar
    Quote Originally Posted by roc View Post
    ...i have also been told its the egr valve but this engine does not have one according to the local stealers.
    Quote Originally Posted by diesel dog View Post
    .Also pretty sure that most engines have EGR valves! ? .
    The 2.0T seems to be the only one in the range that doesn't have one, so at least the dealers were right on that.
  1. z20net power lag
    By richedition100 in forum Engine & Drivetrain
    Last Post: 8th September 2012, 17:35
  2. Vectra c 2.0t Z20NET low power
    By 2Oturbo in forum Engine & Drivetrain
    Last Post: 15th November 2011, 21:23
  3. Problem with z20net Signum loosing power
    By n_hudson in forum Engine & Drivetrain
    Last Post: 7th October 2011, 22:41
  4. most power out of the z20net
    By vectraturbocal in forum Petrol Engine related
    Last Post: 8th November 2010, 20:55
  5. z20net i need more power captain
    By Z20NET in forum Introduce yourself.
    Last Post: 5th August 2008, 00:44
vauxhall signum 2.0t lack of power when hot in first and second
z20net no power
vauxhall signum 2.0 t lost power
z20net check valve problem
z20net
z20net common problems site:www.vectra-c.com
