Results 1 to 10 of 29
Thread: Install finished!
    Apr 2009
    Anglesey
    Default Install finished!
    Hello All,
    Following on from my previous thread (http://www.vectra-c.com/forum/showthread.php?t=80680)) I had already installed my alpine headunit:
    my next task was to install my components, amp and a subwoofer:
    I spent a long time searching this site looking for ideas and in the end I decided to install a single sub behind the cubbyhole on the RHS of the boot. I need to use all my boot space (keen scuba diver!) so this seemed to be the best option for me. I did toy with the idea of cutting the boot trim panel and integrating something into it, but in the end I just wasn't brave enough to start hacking away at it!
    I decided to make a fiberglass sealed box for the sub which would fit tightly into the space available. I've had a play with fiberglass before and apart from being very messy it was nowhere near as difficult as i was expecting. I found a really helpful guide which shows step by step how to do it; http://www.cfsnet.co.uk/acatalog/projects-speaker.html. I didn't get my fiberglass from cfs though as i found it much cheaper on ebay; http://cgi.ebay.co.uk/ws/eBayISAPI.d...m=260412920174
    As the following pic shows I used loads of masking tape over the area I wanted to cover with fiberglass and smeared some wax over the tape to make it easier to release from the mold once set.
    I originally used loads of plastic sheeting all around the build area as the resin tends to get splashed about a bit (at least when i'm doing it!). I built up three layers of mat then left it overnight to go off before taking it out of the car (took a fair bit of pulling but popped out OK in the end).
    In the next step I trimmed the fiberglass to size and made up an MDF baffle to hold the sub. I attached this temporarily to the fiberglass with hot glue and added some braces to increase strength.
    I test fitted it back into the car and found that I had to trim off quite a bit from the top left of the baffle to allow the boot trim panel to be fitted back in place easily. Next I covered the gaps with a few layers of masking tape and filled the gaps from the inside with a few layers of glass mat and resin. The small gaps i filled by mixing up a paste of resin + shredded mat and squashed it into place. Again this was left overnight to set before removing all the masking tape.
    It's not the prettiest of things but it's got no air leaks and seems to be more than strong enough. Thankfully it was still a good fit once all the fiberglassing was done. I attached a couple of bolts through the back of the box to fix it securely to the wall of the boot (no pics of that sorry). Once all the boot trim panels were back in place it was nicely hidden away;
    Now you see it:
    now you don't!
    The front components I installed by following the method shown on Ian's excellent install thread; http://www.vectra-c.com/forum/showthread.php?t=51109. Following his instructions were pretty easy although threading the speaker wire through the grommets was a real pig of a job! I made up some baffles out of MDF by tracing round the old speakers, rather than using autoleads adapters (saved a few quid and possibly will give a better sound). The tweeters were removed from their mountings and hot glued into the door trim panel. Sorry no pics of this bit and they are all hidden away behind the door cards now (it's done exactly the same as in Ian's thread though)
    The amp power wire was fairly easy to thread through and I mounted the fuse inside the battery box:
    Running the speaker wires and interconnects was fairly easy, although i must confess I ran the RHS speaker wire and interconnect down the same side of the car as getting a wire across the whole width of the dash looked like a pain of a job!
    I decided to mount the amp on the back of the seat as it was too big to fit anywhere else really, without going to all the hassle of installing a false floor. I attached the earth by enlarging a hole on one of the supports behind the seat (sanded down to the metal first to get a good connection). I really didn't want to drill through the bottom of the boot + risk rust forming and this seems to do the job ok.
    The last job was to build a cover for the amp and trim it in some carpet to try and make it look a bit nicer.
    It took me quite a while after getting the car to get around to doing the install, but in the end my need for decent sounds outweighed my laziness!
    I'm really happy with how it sounds and it is more than enough for my needs. There is some rattling from the boot area when the music's up high but when driving along this is not really noticeable. In the future (when funds allow!) I will probably add some sound deadening into the doors and boot, and maybe seal the doors fully. For now though i'm a happy chappy!
    Thanks for looking,
    ben
    lanark
    5 Post(s)
    Vehicle : Insignia Elite Nav
    Year : 2012
    Mileage : 9k
    good job mate whats the sound like with your sub being enclosed
    Apr 2009
    Anglesey
    Quote Originally Posted by neverlandandy View Post
    I'm no expert on audio to be able to describe the sound that well I'm afraid, but I would say that it adds some nice extra depth to the music and at higher volumes gives a bit of a massage to your kidneys! The door speakers give the main 'punch' to the bass and this is encouraging me to go ahead and seal the doors + add deadening at some point.
    lanark
    5 Post(s)
    Year : 2012
    Mileage : 9k
    similar to my install improves the sound quality no end especially in an elite with all leather
    Regular Member Vaux-Man-G's Avatar
    Birmingham
    Excellet job, very tidy....!
    Bet it sounds awesome!
    morecambe
    48 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    looks good mate got me thinkin now o no i can feel a spendin spree come in on
    Regular Member Jay Kay 313's Avatar
    Burgess Hill
    Nice work matey very neat and tidy
    Regular Member badback's Avatar
    Runcorn
    Top job mate, well done.
    birmingham
    Vehicle : Vectra gsi
    Trim : Full heated leather
    Engine : 3200
    a very nice job there m8
    Excellent job & thanks for the pics so helpful for others wanting to do something similar ……….
  1. got something finished at last
    By ditchp in forum Styling
    Last Post: 1st July 2010, 07:26
  2. Nearly finished !!!!
    By marky boy in forum Vectra C / Signum Car Chat
    Last Post: 7th June 2010, 15:58
  3. Just finished my R.C Hot Rod
    By Jay Kay 313 in forum General Chat
    Last Post: 17th July 2007, 20:26
  4. Replies: 28
    Last Post: 29th June 2007, 17:10
  5. ice install finished ?
    By david-bell in forum ICE Gallery
    Last Post: 23rd May 2006, 22:06
Where to root amp lead from battery into Astra g
does my vectra c estate have speaker wires in the boot anywhere
vectra c speaker in boot
vectra c boot mat
Where connect speaker leads from amp to existing speaker leads in astra g
vectra c mdf
astra g main wire subwoofer
opel vectra c subwoofer
subwoofer vectra c
