Some of the flashing is coming away from where the roof over my bay window meets the wall of my house.
What can I use to fix this back on
Cheers
Cheers
Hi,
I assume the flashing is a strip of lead let into the pointing between the bricks and draped onto the roof.
You might have to rack a bit of pointing out, to get it to seat back in. Then wedge the lead in place with some small bits of lead packed into the gap. You may actually find the original bits in there to reuse. Usually just small rolls about an inch wide.
Then point it back up with sand and cement.
Will need to spray a bit of water into the joint at this time of year to stop the pointing drying out too quick.
Hope this helps.
