Results 1 to 2 of 2
Thread: Flashing
    Regular Member Damian's Avatar
    Market Drayton
    Default Flashing
    Some of the flashing is coming away from where the roof over my bay window meets the wall of my house.
    What can I use to fix this back on
    North Yorkshire
    Hi,
    I assume the flashing is a strip of lead let into the pointing between the bricks and draped onto the roof.
    You might have to rack a bit of pointing out, to get it to seat back in. Then wedge the lead in place with some small bits of lead packed into the gap. You may actually find the original bits in there to reuse. Usually just small rolls about an inch wide.
    Then point it back up with sand and cement.
    Will need to spray a bit of water into the joint at this time of year to stop the pointing drying out too quick.
    Hope this helps.
  1. 3.2 EML flashing
    By DSmiddy in forum Engine & Drivetrain
    Last Post: 23rd February 2012, 10:02
  2. Help!! LED sidelights flashing!!!
    By shane5861 in forum Electrical & ICE (including SatNav)
    Last Post: 8th July 2011, 10:59
  3. Ps3 Red light flashing
    By bigmac in forum Games Room
    Last Post: 15th October 2010, 12:42
  4. Flashing HIDS
    By paul4400 in forum Electrical & ICE (including SatNav)
    Last Post: 14th October 2010, 23:33
  5. MIL flashing
    By stevedee3 in forum Engine & Drivetrain
    Last Post: 22nd January 2007, 05:05
