Results 1 to 10 of 23
Thread: Size matters, os so i thought with exhausts
    Jun 2009
    Mundesley, Norfolk
    Exclamation Size matters, os so i thought with exhausts
    I'm new to the site and to modding a diesel. I've had the petrol head stage and modded a few petrol cars. I've looked through a few posts about exhaust sizes and several people worried about back pressure on there turbo diesels. From my petrol days i re-call various tuners telling me on turbo'd cars that the turbo itself creats all the back pressure the car needs so oversized donb't matter - i'd have thought it would be the same on diesel - right or wrong ? ? ? ?
    Cambridgeshire
    Correct, diesels with a turbo on do not require back pressure to run effectively. You could have no exhaust on a diesel and if anything it would run better (just be really loud).
    Where as petrols use back pressure from the exhaust to run better
    Jun 2009
    Mundesley, Norfolk
    Thank you mate - knew it was right for petrol cars and assumed so for derv but with so many on this site not sure i needed to ask
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    It's not really right for petrol either.
    Some exhausts 'extract' the exhaust gases by the inherent design causing a low pressure on the port when the exhaust valve is about to open - but this only works for specific engine speeds and harmonics.
    Engines are set up to run on the given back pressure, so removing it will make the engine run worse on it's current settings (usually) - but by changing those settings, better performance can be obtained. I would doubt that this is something you could do easily / cost effectively with modern engines and electronics. This is one reason why people change exhausts etc BEFORE an engine remap....
    Jun 2006
    Kirkintilloch, Scotland
    I'm a bit confused. (not a difficult thing to achieve with me).
    Does my car - a 2004 2.2 petrol auto direct estate - require some sort of balanced back pressure on the exhaust?
    The reason I ask is that I recently had a bespoke stainless steel exhaust fitted to the vehicle. I went for the bespoke system on the grounds of cost and my then belief that there was no need on the vehicle for some sort of balanced exhaust system and that the less the resistance offered by the system the better.
    Dave
    Chester
    Always thought the "Back Pressure" thing was a Fred in his shed term. My assumption would be that a massive exhaust on say a saxo (as an obvious example) would reduce power output as the exhaust velocity would drop massively meaning that exhaust gases aren't extracted effeciently and the engine has to pump a much larger mass of air. Also the reasons Ste mentions.
    The right back pressure helps keep the torque figure up IIRC
    Oct 2006
    Waterloo, Liverpool
    13 Post(s)
    Trim : DESIGN
    Engine : 1.5T (165)
    Year : 2018
    Mileage : 220
    Am I right to assume that changing the exhaust for something, bigger louder or de-catted may not always get the desired results on a turbo petrol engine? I ask this because the main benefit from uprated exhausts has more to do with sound styling and aesthetics than with driveability or out-and-out performance.
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    If you have the ability to utilise any reduction in back pressure from 'performance' or 'sport' exhausts, then you will get more power at the wheels as less power is used to push exhaust gases through the exhaust system (which takes energy from the engine, so reducing power at wheels)
    Regular Member rushy's Avatar
    Vehicle : 9-3 Wagon
    Trim : Turbo Edition
    Engine : TID (1.9 16v)
    Year : 2010
    Mileage : 137000
    Quote Originally Posted by DaveG View Post
    Dave
    If you have a twin fitted the larges bore size that really works for the 2.2 is 2.5 inch if I remember rightly, then at the Y the two pipes need to the be reduced in size. These small engined cars like 1.1 and so on really rely on back pressure thats why they have pea shooters fitted. Makes me laugh when they have big bore's fitted. Mega horsepower cars that run high revs all the time want as little as possible back pressure, hence why they run like a bag of spanners for regular road driving.
  1. Wheel size and tyre size
    By DSmiddy in forum Vectra C / Signum Car Chat
    Last Post: 14th December 2011, 19:19
  2. vec b/c 2.2 exhausts
    By denzilbud in forum Vectra C / Signum Car Chat
    Last Post: 22nd July 2009, 11:40
  3. exhausts
    By billyyoung in forum Vectra C / Signum Car Chat
    Last Post: 11th November 2007, 20:34
  4. Exhausts
    By Steve-E in forum Vectra C / Signum Car Chat
    Last Post: 28th March 2006, 20:40
  5. new exhausts
    By Beavis in forum Vectra C / Signum Car Chat
    Last Post: 28th March 2006, 17:30
