Thread: engine not sounding right on my dti
    Shotts
    Default engine not sounding right on my dti
    awrite there for the last week or so my vectra isnt sounding right when i am driving it and reving it its very tickity does anyone know what could cause this and how to fix it cheers steven
    Glasgow
    Maybe the engine is running hotter due to the heatwave, hot engine = hot oil = thin oil
    When did it last have an oil and filter change?
    Shotts
    it had a service about 6000 miles ago
    Glasgow
    I think its just the extra heat, unless its making worrying noises then i would'nt worry HTH.
    Regular Member John3v36's Avatar
    NI
    timing chain????they need changed when you hear them rattle?? what mileage you have on the car?
    Shotts
    Quote Originally Posted by John3v36 View Post
    just below 90,000 when are they ment to be changed 100,000
    Northants
    Quote Originally Posted by steven_armit View Post
    DTI is 100K for the camchain
    Administrator plasma's Avatar
    On the Forum
    409 Post(s)
    Engine : 150
    Mileage : 74000
    mine was doing over 142k on the same chain, only need to be chained once they turn noisey, (sp?). Also checked the oil level? when these get low they become tickety although not low enough to bring on the warning light
    East Midlands
    There are no reccommendations afaik as to when the chains need replacing,they are designed to last the engines lifetime,however long that may be.
    When thay start to rattle it usually means cream cracker3ed tensioner.i know the early 2.2 dti had a problem regarding oil jets blocking.causing premature wear and failure,but not the 2.0dti.......Hth.
    On the Forum
    409 Post(s)
    Engine : 150
    Mileage : 74000
    Quote Originally Posted by macdad View Post
    I believe your thinking of the 2.2 PETROLS and not the DTI's, afaik no DTI's had issues with oil jets blocking up.
  1. Alarm Sounding every 5 minutes
    By Lamo in forum Vectra C / Signum Troubleshooting
    Last Post: 15th August 2009, 02:19
  2. at the risk of sounding thick...........
    By chrispatch88 in forum Petrol Engine related
    Last Post: 15th June 2009, 20:18
  3. Hollow Sounding Knocking???
    By ChrisFox in forum Vectra C / Signum Car Chat
    Last Post: 2nd April 2008, 20:32
  4. Car sounding a bit rough 3.2 V6
    By korlinski in forum Vectra C / Signum Car Chat
    Last Post: 7th August 2007, 16:54
  5. Horn not sounding right
    By Cheeky_B in forum Vectra C / Signum Car Chat
    Last Post: 7th July 2006, 23:02
