Results 1 to 10 of 11
Thread: spanner light
    Regular Member robk6112's Avatar
    Halifax
    Default spanner light
    My spanner light is showing on my dash does this mean am on limited power? I cant work it out my car my car seems quick one day slow the next. my car is a 150 cdti
    Are you VXR Enough
    13 Post(s)
    Engine : 6.0 V8 Thunder
    is the spanner light on all the time
    Halifax
    you cant tell because after the spanner light it shows the parking brakefault light which comes on after and stays on. I dont think they can both stay on at once if you know what i mean
    Are you VXR Enough
    13 Post(s)
    ?? have you a bulb out then
    Halifax
    no bulbs out. The spanner light came on after i changed the egr valve then went off for two days and now shows every time i start the car
    Full Member Big Sig's Avatar
    Take the battery off for half hour to reset the fault code.
    Clean the lamp contacts too if your 100% sure you don't have a bulb out. The veccys wil use another lamp if the brake light fails. All in the manual ) This should then let you see if the fault light is on, although i would imagine an eml would take preference over a lamp out.
    Halifax
    thank you
    Quote Originally Posted by robk6112 View Post
    I don't know why some people are saying it's a failed bulb when this warning light is to tell you either the handbrake is still on, or you're low on brake/clutch fluid.
    If the car/spanner light goes off once the engine is started, then there isn't a fault. By staying on until the engine is started is just telling you that an old fault code is stored in the ECU.
    Halifax
    That makes sense ill check the fluid now
    New Member midnight999's Avatar
    Jun 2009
    Bridgend, South Wales
    what if it stays on for about 10 mins then goes off
    By Shadrack in forum Vectra C / Signum Troubleshooting
  2. Problems with Air bag light, ABS, Anti Skid & Spanner light
    By WeDesign in forum Vectra C / Signum Car Chat
    Last Post: 4th December 2012, 21:23
  3. Should I Have A Spanner Light aswell as an Engine Light on My Signum?
    By StreetDragster in forum Engine & Drivetrain
    Last Post: 18th August 2012, 11:57
  4. EGR Valve, Engine Management Light & Spanner Light
    By guygreen in forum Engine & Drivetrain
    Last Post: 12th December 2010, 20:09
  5. spanner light then engine management light
    By learoy69 in forum Engine & Drivetrain
    Last Post: 12th March 2010, 20:10
