Results 1 to 10 of 24
Thread: 2.0/2.2dti belt tensioner!?!
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    Default 2.0/2.2dti belt tensioner!?!
    Can anyone who has changed the aux belt on their DTi tell me how easy does the tensioner move to release the belt. My one feels like it seized cheers John
    Regular Member glynn's Avatar
    stevenage, hertfordshire
    there is a bit of tension sometime they can be quite tight and need a very long spanner or lock to spanners together ring end on open end
    Regular Member Dose's Avatar
    Falkirk/dunfermline/alloa
    Quote Originally Posted by glynn View Post
    watch your knuckles lol.
    aye as glynn said mate they can be tight....
    Forfar, Scotland
    Trim : LE/VXR
    Year : 13/07
    Cheers guys, the only reason i ask is i have a squeak coming from the belt on start-up. I bought a new belt but when i went to change it i pulled the tensioner with a 2 foot breaker bar and socket but all the tensioner did was squeak and didn't move enough to release the belt. Just thought the tensioner was siezed. Is it an oil filled damper??
    cant mind to be honest mate(i would assume so tho)...i done one on a zafira a few months back started as a squeak...few days later came in no power steering battery light the lot on...the upper bolt(that bolts into the aircon bracket) had sheared..the tentioner seized and snapped the bolt...mission to get that out to say the least
    Nottinghamshire
    I know this is an old post, but was wondering if you replaced the tensioner in the end and how difficult it was?
    Also, when did you get the squeal? I get it just as the engine starts (not while it's turning over on the starter or when it's running, but just as it starts) and was wondering if it might be the tensioner.
    Thanks.
    Forfar, Scotland
    Trim : LE/VXR
    Year : 13/07
    It sounds like you have the same problem as I did. The tensioner has an oil filled piston that can seize.
    One of the bolts is hard against the chassis but apart from that it's very easy to change.
    Jul 2010
    Warrington / Liverpool
    Anybody know the best place to get a tensioner and what's a good price?
    Think I have the same problem, does anything else need doing with it? Any bolts or such like? Barring the belt obviously lol
    Forfar, Scotland
    Trim : LE/VXR
    Year : 13/07
    Iirc the tensioner comes with the two bolts, I was about 50 quid for the tensioner
    Nottinghamshire
    Thanks. I plan to have a look this weekend. First I need someone to help so the engine can be started while I listen around the engine to see where the squeal is coming from.
    It it does look to be the tensioner, then I'll try to release the tension - if it's stuck then it's off the the garage. If not, I may have a bash at changing it. After all, how hard can it be?
    Interesting to note that both bolts come with the tensioner. I'll double-check that with the dealer as they didn't mention that. Am I right that they different - ones M8 and one's M10, and they're different lengths as well?
  1. Aux Belt Tensioner
    By tatters40 in forum Vectra C / Signum Car Chat
    Last Post: 24th April 2012, 23:02
  2. 2.2dti belt tensioner
    By swvectra in forum Engine & Drivetrain
    Last Post: 7th August 2011, 21:47
  3. Fan Belt Tensioner
    By betty02 in forum Engine & Drivetrain
    Last Post: 9th April 2011, 13:15
  4. Cam Belt Tensioner
    By frenchman in forum Engine & Drivetrain
    Last Post: 19th November 2009, 18:46
