Thread: brake light removal help
    Regular Member Ben_'s Avatar
    Audiville, WM
    Default brake light removal help
    awaiting my clear brake light from terry tibbs (cheques in the post mate), thought i'd investigate how to remove it.....removed the carpet and can't see anyway of accessing it. anybody know how. its a saloon, so will be different from the hatchback.
    any help appreciated it
    cheers
    Devon
    78 Post(s)
    Vehicle : insignia
    Trim : irmscher
    Not sure on saloon mate but hatch can be an arse to do depends whether its enclosed or not if it is enclosed you will have to either drill to holes to access the torx nuts holding the light in (think the pilot holes are marked) or get something flat enough to slide under brake light to release the metal clips
    Regular Member Terry Tibbs's Avatar
    Aug 2007
    Cheers Ben.
    Sorry mate, i thought they'd all be the same. I was fortunate when i removed the clear one to swap for the SRI style that i could literally squeeze the clips together and push the whole thing outwards, it came out in 30secs.
    As above then mate, if its not exposed sounds like either a drill out job, or gently going behind the lense to pop the clips. I'll have a look/search and see if i can find another method to help you out mate.
    Regular Member corsa_si's Avatar
    Apr 2009
    Sheffield
    Going to have to either drill through the boot panel or break it out unfortunately mate. I recommend the latter.
    Audiville, WM
    Cheers guys hammer it is then!!
    So I can just gently lever it out from the outside and that will give me access to slot the new one in?
    Devon
    78 Post(s)
    Vehicle : insignia
    Trim : irmscher
    Might be best holding new one up against old one so it gives you an idea of where the clips are then get a flat knife or some fuler gauges and gently free the clips
  1. Brake Warning light and display error message , BUT BRAKE LIGHTS ARE WORKING FINE
    By JACKALG1 in forum Electrical & ICE (including SatNav)
    Last Post: 24th May 2013, 18:56
  2. Brake line removal
    By mparks8590 in forum Suspension, Wheels & Brakes
    Last Post: 5th December 2010, 17:47
  3. 3rd brake light removal.?
    By Dose in forum Bodywork & Interior
    Last Post: 2nd September 2008, 01:59
  4. 3rd Brake Light Removal
    By Baz07 in forum Electrical & ICE (including SatNav)
    Last Post: 19th April 2008, 22:36
  5. Brake Light Switch Removal
    By Mowster in forum Electrical & ICE (including SatNav)
    Last Post: 9th October 2007, 17:01
