Results 1 to 3 of 3
Thread: Towbar Electrics/Airbag warning light
    Stoke On Trent
    Unhappy Towbar Electrics/Airbag warning light
    Vectra 3.0CDTI Elite Estate
    Hi
    Anybody had problems with airbag warning light, Just wired in 2 plug electrics found all wires into the talegate black so used a pin and a voltmeter to find the stop ,reverse and rear foglight by probably a hit and miss approach now the air bag warning light is on any ideas to get it to function normaly as i'm sure all i must have done with the voltmeter is put in false signal, The plugs work ok when connected to the caravan
    Dave
    Admin plasma's Avatar
    On the Forum
    333 Post(s)
    Engine : 150
    Mileage : 74000
    Maybe you've hit an airbag cable somewhere near the boot? if its just the light clusters you were probing then this shouldnt have caused the problem, but you wont really know until you get the airbag code read which will tell you what circuit its unhappy with.
    Plasma's Tech2 services are now partially open and able to provide services
    Come Join our new forum Insignia Owners.com for all your Insignia chat and needs
    Stoke On Trent
    Eek Towbar Electrics/Airbag warning light
    Thanks for your reply looks like a steelers job I had no probs with my 1.9cdti SRI as Vauxhall had given me coloured wires but there where a lot of black cables in the feed into the tailgate If only it was as simple as my 1956 Series 1 Landrover but it is a bit slower than the Vectra and does rather die at the sight of a hill
  1. Engine electrics warning light
    By datiger79 in forum Electrical & ICE (including SatNav)
    Last Post: 14th May 2012, 21:41
  2. Airbag warning light
    By Deikliw in forum Electrical & ICE (including SatNav)
    Last Post: 22nd February 2012, 14:58
  3. Engine electrics warning light
    By Carl83 in forum Electrical & ICE (including SatNav)
    Last Post: 29th May 2011, 19:20
  4. Engine Electrics - Warning Light Mystery
    By dae36 in forum Engine & Drivetrain
    Last Post: 19th August 2009, 10:03
