Thread: 2.0 DTi Oil
    Stockton on Tees
    confused 2.0 DTi Oil
    My oil low indicator came on yesterday. I have to admit i can't remember when i last checked the level but theres no oil on the floor underneath the car when running or stopped. Its done approx. 5000 miles since i bought it in February (now at 48,000 ish) and i did check the oil once or twice and it was between full and min on the dipstick. My question is does this engine burn oil or should i do some more investigating??
    Thanks for help in advance
    Steve
    morecambe
    43 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    it should use a bit mate but not mega amounts you should really cheak it quite often mate
    Full Member Big Sig's Avatar
    All engines use a little. Some more than others.
    Regular Member John3v36's Avatar
    NI
    wow, 48k is a low mileage dti!! yeah mate keep checking the level and topping up. i check each time i top up / refill my windscreen wash!!
    Stockton on Tees
    Thanks for the help lads. Now this has happened i'm gonna keep an eye on the level. Its full now and i'm gonna get it serviced at 50,000 miles for peace of mind, plus me mate only charges me £50. :-) If its losing loads between now and 50,000 miles i'll have him take a look. Thanks again, anymore ideas r still welcome
    Regular Member Celes's Avatar
    Slovenia, Koper
    Vehicle : Opel Signum
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    I was told that DTi engines use more oil on low miles
    West
    Vx will say there is no problem if your motor is using 1ltr in 1000 miles, my dti has 102k on the clock & doesn't use a drop. my old dti did however use a ltr per 2500miles
    Devon
    75 Post(s)
    Vehicle : insignia
    Trim : irmscher
    touch wood mine doesn't use a drop 140k
    Full Member Teamtom's Avatar
    Vehicle : Vectra C Hatch
    Trim : SRI
    Engine : 1.8 VVT
    Mileage : 53000
    I did speak to a local vaux tech and he said at low miles the DTi is a bit oil thirsty.
    I shouldnt worry too much, just keep an eye on it. Check it every weekend or so. Make sure the engine isnt hot, Left over night is your best bet, and it is on a flat surface. This way you will get a true reading as oil thins out when hot.
    HTH
    Rubbin'z racing Harry!
