Results 1 to 3 of 3
Thread: squeeky breaks
    Nov 2005
    newcastle upon tyne
    Default squeeky breaks
    hi all me again had a problem with squeeky brakes had loads of advice tried a few got a bit sick when nothing worked so took it to a local garage they said brakes fine discs fine so back 2 square 1 it seems to start squeeking when i turn could this be a bearing? & if so how can i check any advice would be great
    Regular Member Big Davie's Avatar
    Jan 2006
    having a giggle...
    Try your heat/dirt shield on the inside of your front disks (you may have to remove your wheels). This happened to me last week and all it was was the shield had bent over on the inside of the disk and was touching it and no more, just bent it back into place and has been ok since.
    Hope this helps you matey....
    Nicking Ya Dinner.
    If you want to check the bearings, jack the car up and spin the wheel, listen for humming sound, and also grab the wheel firmly at both 6-12 and 9-3 o'clock and rock it feeling for play, there is another method but i've only tried it on a rear wheel drive car, and that is to jack one side, start car and put it in gear, and the wheel in the air will spin and the one on the ground will stay motionless, and then you will really hear if there is anything wrong with the bearing.
    From what you say i doub't it is a bearing, as Davie says, check the shield and make sure there is no stone caught in there somewhere, only other thing i can think if is to strip brakes down and give the calipers a real good cleaning, and use plenty of copper grease when you put them back together.
  1. Breaks Knocking
    By mo00oo in forum Suspension, Wheels & Brakes
    Last Post: 26th June 2011, 21:59
  2. Squeeky Brakes
    By Collis in forum Vectra C / Signum Car Chat
    Last Post: 22nd March 2011, 18:17
  3. Flywheel - what breaks?
    By bobmoss in forum Engine & Drivetrain
    Last Post: 22nd April 2010, 18:25
  4. Noisy breaks
    By punkthemonk in forum Suspension, Wheels & Brakes
    Last Post: 25th June 2009, 12:03
  5. Squeeky steering
    By al21784 in forum Suspension, Wheels & Brakes
    Last Post: 6th May 2009, 17:45
