Thread: car lowering advice
    Regular Member darko2301's Avatar
    Croatia
    Default car lowering advice
    since i have mounted my 19" and that bumper i keep thinking that my car is a bit too high, which it is.. despite being an gts (sri) it is still too high imo as there is a big hole above wheels which i find frustrating..
    now i'm thinking about lowering my car.. there are 3 options, just springs, (eg irmscher-eibach), springs + shocks (eg irmscher-bilstein+eibach) or coilovers (eg koni or sth else)..
    now, which would you recommend or take, can someone tell pros and cons of each mentioned? i assume that last 2 options are most expensive, 3-4x more expensive than just springs, but i am still unsure what to get as some people who went just on springs told me that they had a bumpy ride until they changed shocks too...
    coilovers are pretty cool i think because i can adjust height so i can lower the car how much i want to but i can also make it a few cm higher eg in town, sounds pretty useful to me..
    what are yours thoughts about all 3?
    Croatia
    come on guys i know there are some lowering experts on here...
    lanark
    5 Post(s)
    Vehicle : Insignia Elite Nav
    Year : 2012
    Mileage : 9k
    if you have the money go for the best that you can afford ie springs and shocks at once as only putting lowering springs on will put a little more strain on your standard shocks
    Croatia
    so you think that springs+shocks are better solution than coilovers?
    lanark
    5 Post(s)
    Year : 2012
    Mileage : 9k
    Quote Originally Posted by darko2301 View Post
    don't know about that but if you can afford it definately go for springs and shocks
    Regular Member zazaszazas's Avatar
    Cumbria
    I've got Koni springs fitted all around and Koni shock's in the front Bilsteins in the back and i'm loving it
    Sunny Dartmoor
    I'd go for Bilsteins shocks and Eibach springs m8,a great setup and its the same as the Irmscher setup and not too low,hth,good luck........
    Regular Member carl bear's Avatar
    Burton on Trent, Midlands
    coilovers are good, but altering the height will alter the tracking and camber etc so will need settin up each time u change the height.
    also with that bumper u would have a job gettin around with the height set reall low. so if i were u i would use a godo set of shocks and springs.
    Croatia
    cheers guys i'll try to take that combination then, thanks for your help
    This is the last mod .............. remember .......................
  1. advice on lowering
    By byers in forum Handling & Braking
    Last Post: 6th December 2011, 12:03
  2. lowering advice
    By denzilbud in forum Handling & Braking
    Last Post: 20th April 2010, 12:48
  3. Lowering advice
    By Ziggy in forum Handling & Braking
    Last Post: 15th April 2009, 16:05
  4. lowering advice
    By platinumpete in forum Vectra C / Signum Car Chat
    Last Post: 25th September 2008, 21:35
  5. Need advice on Lowering
    By bizerk in forum Handling & Braking
    Last Post: 15th September 2008, 18:33
