Thread: emission light flashing (HELP)
    south wales
    Default emission light flashing (HELP)
    hi all,was driving down the motorway when i felt it loose power and the emission light was flashing,I pulled over and the engine felt like it was running on 3 cylinders but once revved past 2k rpm it stopped juddering and sounded on all 4 now its constanly sounding like its on 3 and driving horrible its a 2003 2.2 non direct,any advice would be great cheers
    Administrator plasma's Avatar
    On the Forum
    405 Post(s)
    Engine : 150
    Mileage : 74000
    dont drive with it flashing, it will kill the cat stone cold dead.. Get the codes read right away mate.
    south wales
    could it be a coil pack
    11 Post(s)
    Quote Originally Posted by vectrac20tsri View Post
    It could be. But then again there could be 1 of 101 things wrong. Having the fault code(s) read out takes away all the guesswork, which at the moment is what you're doing.
    south wales
    ok cheers mate will get it read today
    11 Post(s)
    You can DIY read the fault codes.
    http://www.vectra-c.com/forum/showthread.php?t=81742
    south wales
    got it read today and it came up,missfire detected cylinder 2,and egr valve,i changed the plugs as they were well past it and its still the same,below 2k rpm its on 3 cylinders and over 2 its on all 4 so i think its either compression or coil pack
    Jun 2009
    South West
    Fault code reader can't detect spark plug fault as they are not electronic. They can't detect compession either . It will be coil pack .
    Regular Member rushy's Avatar
    Vehicle : 9-3 Wagon
    Trim : Turbo Edition
    Engine : TID (1.9 16v)
    Year : 2010
    Mileage : 137000
    Was the engine noisy at all mate, the chains are a week part of the 2.2, snapping or jumping a tooth or two is quite common.
    south wales
    did a compression test and cylinder 2 has hardly any compression and the chain is abit noisy,gonna get another pre face 2.0t what can i expect to pay
  1. Emission light on
    By Porl in forum Engine & Drivetrain
    Last Post: 11th February 2013, 23:10
  2. Emission light
    By vectra 120 in forum Engine & Drivetrain
    Last Post: 8th June 2010, 10:26
  3. spanner light reset emission light now on HELP!
    By johnny boy67 in forum Vectra C / Signum Car Chat
    Last Post: 7th December 2009, 12:07
  4. emission light help!
    By platty in forum Engine & Drivetrain
    Last Post: 22nd August 2008, 18:09
  5. emission light
    By pipamish in forum Engine & Drivetrain
    Last Post: 20th March 2008, 08:29
