Thread: which springs do i need?
    St Neots
    Default which springs do i need?
    just about to order my lowering springs am going for the PI 45mm springs but i cant find a listing that say they are for the 1.9 cdti. they list for the 1.8/2.0/2.2 petrol and the 2.0/2.2 dti/3.2.
    which one should i buy.
    http://cgi.ebay.co.uk/PI-Lowering-Sp...3A1%7C294%3A50
    thanks
    St Neots
    bump ........ anyone?
    Regular Member satty's Avatar
    May 2007
    Newcastle
    bump... id also like to know the answer to this
    Wondering lonely as a cloud
    26 Post(s)
    Vehicle : M5
    Trim : Nothing needs adding
    Engine : 5.0 V10
    Year : 07
    Mileage : 37000
    Check your axle weights found on the B pillar info label with 1- (front axle weight) and 2- (rear axle weight) before them and then contact the seller and ask them for the information from the kits. Remeber if you drop significantly from standard i.e. 30mm plus you should have a full geometry setup done on your car which can add about £80 to the cost if you don't do it you risk shredding your tyres in next to no time.
    Regular Member bobby-tupper's Avatar
    LEEDS, W.YORKS
    Vehicle : 07 Estate
    you could just try ringing the seller,they should be able to find out straight away for you.hth
  1. replacing standard springs with Sri springs
    By mon in forum Handling & Braking
    Last Post: 31st December 2012, 22:03
  2. springs? coilovers? shocks/springs?
    By Dan. in forum Vectra C / Signum Car Chat
    Last Post: 4th March 2011, 19:01
  3. Replies: 5
    Last Post: 21st July 2010, 16:14
  4. vxr springs
    By supersione in forum Handling & Braking
    Last Post: 18th July 2010, 16:21
  5. 2.0T SRI Springs
    By Baz07 in forum Parts for sale
    Last Post: 9th July 2008, 13:28
