Thread: Battery disconnection - Help please!!
    Regular Member jujitsuboy69's Avatar
    Bridgend
    Default Battery disconnection - Help please!!
    Hi guys, do you have any tips on disconnecting the battery? (I'm trying to put the ECU into "learn" mode)
    The only trouble is, I can't! Is there some kind of trick to it? I've undone the bolts on the terminals, but cant get them to shift!!
    Any tips would be appreciated
    Regards
    Adam
    Regular Member Robbie69's Avatar
    large flat blade under and persuade it to move!
    Tap it from side to side should be able to move it just enought to crack it then ease from under remembering not to have a metal handle & earth yourself & make a nice spark .....
    Newcastle under Lyme
    WD40 or similar
    South Wales Assistant Regional Organiser davidjameswest's Avatar
    llantwit major
    when you get it of use some white grease mate will be easier to get off next time but also protects the connection too
    Bridgend
    Thanks for the suggestions fellas, will try some out tomorrow - I tried using a small prying bar to remove/loosen it but I could see the plastic underneath straining, so I thought best try here first!
    Think i'll try soaking it in WD40 get it loosened up hopefully
    llantwit major
    if you want to come to mine mate i have some panel removing tools we can try as im only in barry, you coming to the meet at ogmore mate
    Quite a coincidence. I did a few repairs on my mothers 10 year old micra including repairing the connector on the back of a H4 lightbulb which crumbled when I took it off due to it shorting and melting the plastic. Whilst doing this the Negative terminal was completely encased in acid powder and as I turned my ratchet to loosen the bolt it shattered too. Being 7pm the fix was from B&Q in the form of earthing copper which is used to rap around pipes until i could byuy a new connector from halfords today. Be very careful that you dont snap the whole terminal off.
    Bridgend
    Panic over..the WD40 method seemed to have worked!
    The ECU has now been reset
    Thanks everyone for your help!
    Quote Originally Posted by jujitsuboy69 View Post
    Pleased you have it sorted & hope you applied a little petroleum jelly 'Vaseline' or similar prior to refitting .............
  1. EGR disconnection on 3.0 CDTI
    By diesel dog in forum Y & Z30DT Specific
    Last Post: 6th September 2012, 07:01
  2. battery wiring block next to battery 150tdci - HELP
    By jameslunt in forum Electrical & ICE (including SatNav)
    Last Post: 2nd July 2012, 07:19
  3. Battery Light ON - 14.1 volts at battery
    By snapsnap in forum Electrical & ICE (including SatNav)
    Last Post: 6th December 2011, 13:55
  4. canbus disconnection
    By Al 22 dti in forum Vectra C / Signum Car Chat
    Last Post: 23rd March 2011, 08:28
  5. Air box mod & battery disconnection
    By vectravirg in forum Vectra C / Signum Car Chat
    Last Post: 13th November 2006, 20:05
