Thread: car alarm
    Regular Member decks's Avatar
    Apr 2008
    nothern ireland
    Vehicle : 2.0t btcc
    Default car alarm
    my alarm keeps going off could anybody tell me the fuse to take out to solve this prob for the time being its says in the hand book fuse 21 5amp removed this fuse and still going off any ideas or else i will have to leave my car unlocked all night.
    Carmarthen
    Vehicle : Insignia
    Trim : Sri
    Engine : 140 Ecoflex S/S
    You'll have to disconnect the siren in the boot (pull the multi pin connector out) as the siren has a battery back up. Hence when you pull the 12v fuse out, it carries on. HTH
    Regular Member dlm71's Avatar
    Cheshire
    Just a thought! have you tried disabling the interior sensors to see if it is them causing the problem, they are quite sensitive, hot weather, window slightly open and even the vent set to the windscreen will cause the alarm to go off if the wind gets up enough? if it is you will still be able to set the alarm and have some protection
    Apr 2008
    nothern ireland
    Vehicle : 2.0t btcc
    what size is the multi pin connecter will this just disable alarm and not affect anything else
    11 Post(s)
    To lock the car without setting the alarm - reach in through one of the other doors and press the lock button on the drivers door, then exit out the door you reached in through. All doors will be locked via the central locking, BUT the deadlocks won't be set.
    Cheshire
    Quote Originally Posted by decks View Post
    it just disables the interior sensors, it is used when you leave pets or children in the car and you need to lock it, but if the doors are opened without the key the alarm will go off, give it a try
    Apr 2008
    nothern ireland
    Vehicle : 2.0t btcc
    no good tried that still going off doing my head in have to leave it unlocked tonight
    Apr 2008
    nothern ireland
    Vehicle : 2.0t btcc
    if i pull the multipin connector in the boot will i still be able to lock the car
    Carmarthen
    Vehicle : Insignia
    Trim : Sri
    IIRC, yes.
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    Does anyone know how much the sounders cost from vx. My one is missing (obviously had the same prob) and when the alarm goes off it's pretty pathetic with just the lights flashing
  1. Car alarm keeps going off
    By si_hoss in forum Vectra C / Signum Car Chat
    Last Post: 29th April 2015, 18:37
  2. Alarm keeps going off?!
    By Ben Chiles in forum Electrical & ICE (including SatNav)
    Last Post: 17th April 2012, 22:26
  3. Alarm led?
    By Vectra Karl in forum Electrical & ICE (including SatNav)
    Last Post: 9th January 2012, 22:43
  4. alarm keeps going off
    By the fisherman in forum Electrical & ICE (including SatNav)
    Last Post: 25th July 2011, 01:22
  5. how do i get to my alarm??
    By bangty 1 in forum Vectra C / Signum Car Chat
    Last Post: 5th November 2010, 19:51
