Thread: Blown bulb indicator on dash.
    Regular Member videodoctor's Avatar
    Blackpool
    Default Blown bulb indicator on dash.
    My 'blown' bulb indicator keeps flickering on and off ,now and then ,but its been doing this for weeks.I was wondering if there was a common bulb that always gives trouble(ie bad connection) or will i have to wait until its permanent.
    Regular Member Swaite53's Avatar
    South Wales
    It's quite possible a bulb about to blow. Mine tells me which bulb it is, if yours doesn't, it's best to wait for it to come on again, then turn all the lights on and go around the car to look for the offending one. Look carefully at the rear of the car, as it'll turn another bulb on, so can make it hard to spot which one is not working at a quick glance.
    It could also be a bad earth on the offending bulb. Just try giving the contacts a quick clean
    Regular Member m3ath3ad's Avatar
    Aug 2007
    Minehead
    mine does that to yea could be to warn you its about to blow
    Regular Member addyboy1982's Avatar
    Northampton
    I had that on my old DTI, turned out to be a bad earth on the O/S headlight bulb
    Regular Member djr69uk's Avatar
    Midlands
    i had this... on and off for about a week then finally a headlight bulb gave up the ghost
  1. hid bulb blown
    By n8sby in forum Styling
    Last Post: 12th March 2011, 21:39
  2. does a blown bulb cause other problems?
    By admob in forum Vectra C / Signum Car Chat
    Last Post: 28th June 2010, 22:04
  3. Blown Bulb Warning Help??
    By Jolly in forum Vectra C / Signum Car Chat
    Last Post: 18th September 2008, 00:15
  4. Blown bulb warning light on dash??
    By Genterz in forum Vectra C / Signum Troubleshooting
    Last Post: 9th August 2008, 11:10
  5. Bulb blown!
    By Vectra Singh in forum Vectra C / Signum Car Chat
    Last Post: 11th February 2008, 18:57
