Thread: Gearbox Oil Leak
    Regular Member Jezzy's Avatar
    S.E
    Default Gearbox Oil Leak
    While under my car yesterday undoing the sump nut I caught a glimpse of an oil stain on part of the underside of the engine bay. Had a closer look today and it looks like it's coming from the driveshaft seal - inboard end according to Haynes.
    Does anyone have experience of this on theirs and know roughly how much it costs to fix? Cheers!
    Regular Member m3ath3ad's Avatar
    Aug 2007
    Minehead
    yep i hed the same problem on mine when i had the alternator fix they damaged the seal, the seal was i think £6 something and you might need some gear box oil to unless you save the fluid you get there
    S.E
    Quote Originally Posted by m3ath3ad View Post
    Blimey, I reckon I can stretch to £6
    But...how do you get the new seal in there - it's not £100's to get it fitted is it?
    Aug 2007
    Minehead
    first thing got to take the wheel off then you got to take the drive shaft out to that where you got to try and catch the gear box oil so if you feel confident to do it the fire away but if not then a garage joby
    S.E
    Well if it's something I could do at home with maybe a lil difficulty, then I guess it's easy for a garage so they shouldn't charge shedloads. I was having visions of gearbox having to be removed! Cheers for your help Mate.
    Aug 2007
    Minehead
    no probs mate at all shoudnt cost to much at all
    Jun 2014
    Scotland
    Vehicle : Vectra 1.9 cdti
    Trim : sri
    Engine : 1.9 150
    Mileage : 174,000
    found this....http://www.vxronline.co.uk/forum/sho...oil-leak/page1
    The fluid dripping frome same place on my vectra is cherry red colour.....is there a gasket between gearbox and engine?
    Regular Member Wilson118's Avatar
    Mar 2014
    Scotland
    Vehicle : 1.9 cdti Sri
    Trim : Ex2
    The gearbox oil used originally I'm sure is standard red colour that's what came out my gearbox anyways.
  1. gearbox and engine oil leak
    By humelis in forum Engine & Drivetrain
    Last Post: 2nd December 2011, 15:21
  2. Gearbox oil leak!?
    By m3ath3ad in forum Engine & Drivetrain
    Last Post: 25th April 2009, 20:35
  3. MoT Advisory - Gearbox Oil Leak
    By Adamant in forum Vectra C / Signum Car Chat
    Last Post: 21st May 2008, 15:09
  4. Gearbox leak?
    By Jim Bob in forum Vectra C / Signum Car Chat
    Last Post: 1st June 2007, 17:15
  5. Gearbox Oil Leak
    By danielpayne in forum Vectra C / Signum Car Chat
    Last Post: 8th February 2006, 13:39
help oil leak on gearbox on2006 vectra c 3.0
vectra c 1.9cdti gearbox oil leak
gearbox gasket for vectra c z30dt
vectra c auto box oil leak
vectra c driveshaft leak
vauxhall vectra oil leak
gearbox fluid leak on vectra 1.9 cdti 2006 model
vauxhall signum 3.2 v6 auto gearbox leak
gearbox oil leak on vectra c
when was the vauxhall auto gearbox oil leak fixed
vectra 1.8 sri gearbox oil leak
vectra gearbox oil leak
how to fix inboard seals ends of driveshafts gearbox leak
oil leak in gearbox vectra 1.9
vectra c driveshaft oil seal replacement www.vectra-c.com
gearbox oil leak vauxhall vectra c
oil leak from under car vauxhall vectra
vauxhall insignia oil leak from drive shaft
Vectra c oil leak from gearbox
