Results 1 to 10 of 15
Thread: brake fluid
    Oct 2006
    southampton
    15 Post(s)
    Default brake fluid
    looking for some advice on brake fluid, as I'm not cutting corners for quality I would like to know peoples opinions on the best brake fluid for my new setup. appreciated
    Regular Member glynn's Avatar
    stevenage, hertfordshire
    all break fluids are dot 4 so it wouldnt make any different in brands
    Oct 2006
    southampton
    15 Post(s)
    whats the difference btween DOT 4 and DOT 5.1, keep seeing it but no idea of the differences.
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    Sorry to disagree but you get dot 3 (not for abs), Dot 4 (more than adequate for normal to fast driving and dot5.1 (extreme). As long as you don't mix synthetic with mineral you'll be ok.
    The difference is the boiling points
    Oct 2006
    southampton
    15 Post(s)
    so is it the density that is different. and would i see any benefits from the 5.1
    Forfar, Scotland
    Trim : LE/VXR
    Year : 13/07
    You will if you intend to drive it REALLY hard or use it for track days
    Oct 2006
    southampton
    15 Post(s)
    The reason i wanted to upgrade breaks is, on the way to work, normally about 3am on Monday mornings, there is a lane that is just meant to be driven if you know what i mean, normally over the motorway speed and at the end of it you get to a roundabout and its hard braking, i got brake fade one morning and thats why i decided to look at upgrading them. think 5.1 is the way to go for.
    Forfar, Scotland
    Trim : LE/VXR
    Year : 13/07
    Brake fade was more than likely just the pads/discs. For brake fluid to boil you have to be accelerating and braking all the time
    Oct 2006
    southampton
    15 Post(s)
    cheers for the advice peoples
    As John said, to boil the standard DOT4 fluid you'd have to be giving it some serious what for on the track for that to happen - you're more likely to suffer brake fade first with your discs. When I fitted my VXR fronts I contemplated sticking in DOT5.1 but decided it really wasn't going to give any benefits at all, so I just stuck with the standard DOT 4.
  1. brake fluid
    By vectraross in forum Vectra C / Signum Car Chat
    Last Post: 23rd November 2012, 01:09
  2. Brake fluid
    By ed taylor in forum General Chat
    Last Post: 8th July 2012, 06:09
  3. Dot 5.1 and Dot 4 Brake Fluid
    By smitd004 in forum Suspension, Wheels & Brakes
    Last Post: 26th July 2011, 12:36
  4. Brake Fluid Q
    By Jezzy in forum Vectra C / Signum Car Chat
    Last Post: 22nd July 2011, 11:29
  5. Brake Fluid
    By parapaul in forum Suspension, Wheels & Brakes
    Last Post: 23rd August 2008, 12:27
