Results 1 to 3 of 3
Thread: DAB Radio Amp
    chepstow
    Angry DAB Radio Amp
    My 2008 Vec Design was parked in the street the other day when a van drove by and an unsecured sheet of wood slid off it onto my roof, putting some small dents on the roof and damaging the aerial.
    Of course Mr Van Man got out, put the sheet back on and drove off. No one noted the reg number or any other details. The Radio now doesn't work, DAB or FM.
    The black plastic box that the aerial screws into is an ampliflier and could be damaged. I have ordered a new aerial at around £20 but am sure the amp is damaged which is £78. The plastic cover for the amp is distorted and not fitting flush with the roof.
    Does anyone know how the black plastic box is fixed to the roof ? It also houses the rear window washer. Has it got to be removed from inside the car; ie from under the headlining. Does it just unscrew or is there some special clips. Can the plastic cover be removed from the outside? Any help will be much appreciated.
    Devon
    75 Post(s)
    Vehicle : insignia
    Trim : irmscher
    I'm sure you will have to pull headlining down and unscrew a single nut securing the aerial to the roof and i'm sure you will find these are sealed units ( i maybe wrong)
    I would check connections first when you pull headlining down you maybe lucky and with the force of the impact it might of dislodged the connection
    chepstow
    Thanks for the reply. I will investigate further and let you know.
  1. CDC 40 radio
    By dave b in forum Electrical & ICE (including SatNav)
    Last Post: 23rd October 2012, 23:20
  2. Radio 1
    By vec-cal in forum Electrical & ICE (including SatNav)
    Last Post: 31st August 2010, 00:17
  3. my radio
    By the fisherman in forum Vectra C / Signum Car Chat
    Last Post: 18th May 2010, 21:29
  4. CD 30 Radio
    By Stevel in forum How much is it worth? (THIS SECTION IS NOW CLOSED)
    Last Post: 13th July 2008, 17:15
