Thread: Enabling xenon on ecu trough tech2?
    Netherlands
    Question Enabling xenon on ecu with tech2?
    Quote Originally Posted by merikiito View Post
    Got my mate to enable Xenons in the Underbonnet ECU and volia they work!!!!
    So to recap:
    Vauxhall Xenons can be retro fitted
    All that is required is
    1.an earth added to the plug that fits into the headlight
    2. The headlight adjustment motor swapped out for the standard one and then rewired to suit (you will need the plug off the old headlight)
    3.enabling in the under bonnet ECU via Tech2
    There is no need to have the self leveling sensors and no error code is thrown up when they are not fitted.
    No bulb out error codes are thrown up either.
    So thanks go to:
    Shunter and Stevedee3 for their input which led to me to the UECU and my mate Ian for the Tech 2
    Photos to follow when the car is clean.
    Another mod completed on to the the next............
    i have succesfully retrofitted the xenon on my vectra c
    and it works with the engine off (no checkcontrol) and with engine on it flickers very fast
    so it needs to be tech2'd but i went to the opel dealer today and a friend of my works there and he didn't find the function to activate the xenon,
    so my question here is: does somebody know the ehmm the walktrough for activating the xenon?
    and whats the underbonnet ecu? (sorry for the bad english)
    Thanks in advance
    Regular Member kenp's Avatar
    Kr. Hyllinge, Denmark
    Engine : 2.2 Direct
    The underbonnet ECU is called UEC in Opel terms..
    And its in the UEC they have to activate Xenon/AFL its in the variant configuration..
    Netherlands
    Quote Originally Posted by kenp View Post
    Thanks man for the info
    ps. i sent you a pm back
    Regular Member benny's Avatar
    Feb 2006
    dudley
    cim has to be told it has them fitted ...so does the ipc (dash) .....
    Netherlands
    Went to the opel dealer this morning and works like a charm now,
    Thanks for the how-to by kenp
    in the menu i saw that you can enable different options like:
    xenon headlights: present / not present
    Headlight washer: present / not present
    etc.
  1. Xenon activation on via Tech2
    By BigWilko in forum Electrical & ICE (including SatNav)
    Last Post: 29th November 2011, 21:37
  2. Enabling BC on CD40 Opera?
    Last Post: 6th September 2011, 00:22
  3. Enabling BC1, BC2 etc
    By Meady in forum Electrical & ICE (including SatNav)
    Last Post: 18th February 2011, 21:31
  4. AMP power cable trough motorhood??
    By vectralex in forum Electrical & ICE (including SatNav)
    Last Post: 25th April 2010, 13:57
  5. Enabling BC Controls
    By Signum Dek in forum Electrical & ICE (including SatNav)
    Last Post: 5th April 2010, 21:12
how to activate xenon option vectra c
how to activate xenon on tech 2
activate xenon tech2
vectra c xenon headlights retrofit
activating xenons in tech 2
tech2 vectra xenon
Tags for this Thread
