Results 1 to 10 of 13
Thread: astra vxr engine in my vec yay or nay?
    Regular Member pogo's Avatar
    Feb 2006
    Vehicle : Audi
    Trim : A5
    Engine : 2.0 turbo petrol
    Default astra vxr engine in my vec yay or nay?
    as above is this conversion possible as ive looked into geting 240bhp from my z20net and it would take many £000s so i wonder if this conversion is more feasible,what yous think?
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    Nay, can bus way too complicated mate
    Regular Member Super T's Avatar
    May 2007
    On the Levels
    If you can get 340bhp from the Saab 2.0t why can't you get 240bhp from yours?? Check Abbott racing see if they can helpthat may be my next port of call
    Feb 2006
    Vehicle : Audi
    Trim : A5
    Quote Originally Posted by Super T View Post
    worth a call mate but cant understand how other 2.0 turbo engines are capable of huge bhp but not this one!
    Northampton, UK
    The Saab 2.0T gets what???!! 340!? Now thats a remap and a half LOL!
    Regular Member SRimonkey's Avatar
    wednesfield
    sounds like more than remaps like uprated components all over the engine from the exhaust all the way to the front an then it might add up
    Oct 2006
    Waterloo, Liverpool
    13 Post(s)
    Trim : DESIGN
    Engine : 1.5T (165)
    Year : 2018
    Mileage : 220
    In addition the Z20LEH engine in the Astra VXR is Vauxhall's own jobbie and a million miles away from the Z20NET and is regarded as more tunable than the Z20NET, partly because so little work has been done to maximise the tuning potential of the Z20NET.
    Also consider that BSR can tune the non-VXR 2 litre turbo engines that were in the Astra from 170 or 200bhp to 240 bhp in a single stage remap without changes to ancilliaries like exhaust and engine components.
    The same will allegedly be the case with the different strengths of the 1.6 turbo engines tuning them up to 240bhp or even higher in a single stage.
    Jan 2006
    Dalriada
    Im pretty sure Abbott dont do much for the vectra 2.0T - someone has asked them before IIRC..
    Leicester
    Quote Originally Posted by pogo View Post
    Its the exact same hardware as in the Saab, but the management is different and the Saab tuners have developed the Saab conversions more than the Vauxhall tuners have done to the Z20NET.
    Quote Originally Posted by SRimonkey View Post
    The Z20NET is good for 300/330bhp before the internals need changing.
    Leicester
    The Astra Z20LET as found in the Astra G GSi and Zafira A GSi can be taken to 240bhp with just a re-map.
    In the Astra H, the 170PS Z20LEL and 200PS Z20LER are idenditcal to the Z20LET with different mapping to produce 170 and 200PS respectively.
    So as said, all three specs of this engine can be taken to 240bhp. They also can be taken to 290bhp with a VXR turbo, re-map, exhaust, intercooler and VXR injector rail
    The best kept secret is the Astra H and Zafira B's Z20LEL and Z20 LER. If you fit the turbocharger and injector rail from a Z20LEH VXR engine, you can programme the car as a VXR with TIS and Tech 2.
    The VXR engine (Z20LEH) is identical to the LEL, LER and LET but has high yeild forged pistons with teflon coats, under piston oil spray jets for cooling, but the compression ratio is identical to the other engines. So programming it up with Vauxhalls software will make it run and drive exactly like a VXR.
    The higher spec engine components in the Z20LEH were done to pass durability testing.
  1. astra let engine turbo wanted
    By happypostie in forum Engine & Drivetrain
    Last Post: 6th October 2010, 20:49
  2. astra vxr or a vectra vxr engine ?
    By turbosiggy in forum Vectra C / Signum Car Chat
    Last Post: 2nd August 2010, 09:18
  3. Vec C 2.0T & New Astra 2.0T. Same engine?
    By Ghosty621 in forum Vectra C / Signum Car Chat
    Last Post: 24th November 2006, 00:00
  4. Astra 2.2 engine covers fit vectra 2.2?
    By rushy in forum Vectra C / Signum Car Chat
    Last Post: 23rd August 2006, 19:54
  5. astra 120 engine spec
    By mike houston in forum Diesel Engine related
    Last Post: 17th May 2006, 15:08
