Thread: 2.2 DTI engine shake on switch off.....
    Regular Member s0501291's Avatar
    Warrington
    Default 2.2 DTI engine shake on switch off.....
    Hi All
    just wondering if this is normal? The car runs great, no problems AT ALL, but when I switch off the engine the whole car shudders as the engine switched off. Had the bonet open and watched the engine when I switch off and the engine does shake quite a lot on switching off... IS THIS NORMAL??
    Pete
    Regular Member Avenged's Avatar
    Liverpool
    engines do shake!
    either one of ure engine mounts has gone.. or it's somethin else!
    sure a few others will be along with more info!
    Regular Member addyboy1982's Avatar
    Northampton
    My old DTI used to shake slightly when switching off, it never got worse over 14 months and 31k miles, I would say it's a trait of your engine.
    Regular Member redraptor_141's Avatar
    Sailing the High Seas on HMS Ark Royal
    ive got a 2.0DTi and it has done this since ive bought it. even went to the dealers about it. they said to not worry as its just, the engine has such a high compression ratio theres a lot of pressure and momentum in the engine when it stops. apprenltly to stop all it does is cut the fuel. they said its normal as long as it doesnt do it exsessvly and by that they mean it thrashes about and usually breaks somthing in the prossess lol.
    mine does it on startup as well. if its that bad just wip to the dealers and thell check it out for you
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    All diesels 'kick' more than a petrol when switched off, it's normal.
  1. random engine switch off
    By nick6515 in forum Engine & Drivetrain
    Last Post: 8th November 2012, 19:19
  2. Problems after the Y30DT engine switch.
    By jaakoppi in forum Engine & Drivetrain
    Last Post: 23rd March 2011, 15:33
  3. 2.2 Direct Recall - Engine Management Switch
    By rheumatoid in forum Vectra C / Signum Car Chat
    Last Post: 2nd July 2010, 20:51
  4. Engine Control Clutch Switch
    By 3.2wales in forum Vectra C / Signum Car Chat
    Last Post: 29th December 2009, 21:08
  5. shake that A##
    By murf2484 in forum Comedy & Humour
    Last Post: 20th May 2006, 12:57
vectra c engine judder when switch off
vectra c 2.2dti engine shudder
