Page 1 of 4 123 ... LastLast
Results 1 to 10 of 31
Thread: Should the Spacesaver wheel be 2" smaller
    Regular Member 67688c's Avatar
    Apr 2008
    In UK
    Default Should the Spacesaver wheel be 2" smaller
    I notice on my new Insignia which is fitted with the 7 spoke alloys 245/45/18 tyres, that the space saver spare is only 16" diameter.
    Does that sound right to you?
    Surely the steering is going to pull to one side. I know they are only intended as a tempory measure, but it seems wierd to me.
    Regular Member KieronGSI's Avatar
    Apr 2008
    Aylesbury
    Is that the space saver including tyre or just the space saver itself?
    cambs
    hi
    the overall size of the spacsaver wheel should be the same.
    the wheel is also only to be used for a limited time untill you are able to get the wheel fixed.
    and yes they drive like crap. i put a proper steely in my boot.
    hope this helps
    Apr 2008
    In UK
    Quote Originally Posted by KieronGSI View Post
    I got the size off the side of the tyre which was fitted, IOW on the side of the tyre it states its 16" diameter and not 18" forget what the other figures were, as it was mainly just the diameter I was checking.
    Do you think they may have put in the wrong size spare wheel, a question for the dealer obviously.
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    My vec has a 16inch space saver tyre with a 115/70R16 tyre on it. It looks about 2 inches overall smaller than the standard 17" wheel/tyre. I'm trying to find a full size spare at the moment though as i tow a caravan and don't trust that wheel
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    The cost saver is smaller, and it doesn't really matter as you are on restricted speed and distance.
    My advise would be to NEVER put one on the front positions. ALWAYS swap a rear tyre to a front flat and put the cost saver on the rear. They will not handle the power and steering as well as simply stopping the rear from dragging on the road.
    Oct 2006
    Waterloo, Liverpool
    Trim : SRI NAV XP
    Engine : 1.9 CDTI 150
    Mileage : 72K
    Within the permitted speed limit of 50mph, the car does not sit or steer any differently with a spacesaver on. It's the embarrassment of having a big gap in the wheel arch and the steel rim and yellow label that is the real problem.
    Northampton, UK
    If you look in your car manual, it tells you how to fit a full size wheel in the spare wheel well. I've got a spare 17 GSI wheel in mine.
    Compare the tyre sizes, not the wheel sizes
    At least you have a spacesaver, mine was one of the Vectra C that didn't get one
    Instead we get 10 years AA membership, and I've used it once for a puncture
    Apparently AA are none too happy at this arrangement, and I get letters every 6 months advising me to upgrade my membership!
    May 2007
    south ockendon
    although the space saver is a 16" rim, it should have roughly the same rolling radius as your 18" rims
  1. Would i be mad to downsize from 19" vxr rims to a smaller rim?
    By signum_rob in forum Vectra C / Signum Car Chat
    Last Post: 2nd January 2013, 12:36
  2. Spacesaver or steel wheel
    By coldo in forum Vectra C / Signum Car Chat
    Last Post: 16th January 2012, 14:51
  3. anyone else got rid of there spacesaver???
    By Jow20 in forum Vectra C / Signum Car Chat
    Last Post: 27th November 2011, 18:49
  4. Replies: 22
    Last Post: 27th August 2011, 14:37
  5. Replies: 3
    Last Post: 19th October 2008, 15:03
space saver wheel sizes
space saver tyre sizes
insignia spac saver spare is smaller diameter than fitted wheel
insignia 24545 r18 steel spare replace space saver
space saver wheel smaller diameter
Space Saver Wheels
my spacesaver wheel is smaller diamete
can a spacesaver wheel be smaller
are space savers usually a smaller diamter
space saver wheel
what size should a space saver wheel be if car wheels are 15 inch
size of space saver wheels
ok to use a smaller spare wheel fit insignia
where is spare saver tyre insignia
what size space saver wheel do i need
