Thread: Management Light on and car booked in
    Regular Member ANDY W's Avatar
    May 2007
    WINSFORD
    Default Management Light on and car booked in
    Yesturday my cars Magagement light came on or at least I think it is, its the outline of a car with a spanner on it. Anyway it came on and I had very limited power so as soon as I could I pulled over and turned the engine off. Started it up again and it ran ok and no light on.
    Today the light came on 3 times in a 7 mile trip and 2 times back again and the light now stays on when you turn the ignition lights on.
    I have booked it in to the stealers for Monday and then removed the Remap and put it back to 150mode which cleared the light. I took it for a run and all seemed ok untill I was overtaking a car and all of a sudden I lost all power and the light came back on but he engine still ran but limited power.
    I looked at the Swirlvalve setup and all looks ok and the EGR was electronicaly blocked off with my remap so does anyone have any ideas?.
    Luckily he car is under Manufacturers Warranty untill mid September
    Apr 2009
    stockton-on-tees
    sounds like 1 or your vacume pipes has a split in it
    May 2007
    WINSFORD
    Thats a new one on me matey. I have had a short ride today and its behaved its self but the light still does stay on when you turn on the ignition.
    I just want the stealers to know that I have a few ideas what it could be so they dont try to be clever.
    Any more ideas folks
    Regular Member gibbon7000's Avatar
    lincs
    I know yours is a diesel but my old mans 2.2 Signum (petrol) had excatly the ame probs, turned out to be the high pressure fuel pump £300 ( done under warranty)
    EVERYWHERE
    HP pump is possible,also turbo boost sensor,split hoses,EGR valve,swirl flaps etc.Right now a code reader would be handy,so that you can read the codes before the stealer does.But I guess it's no problem if it's still under warranty.
    May 2007
    WINSFORD
    Well they have had a look and they reakon that it needs a DPF Regenerate which seems odd as it only did its job about 3 weeks ago and they say that it needs a ECU upgrade which they say they will pay for subject to a full service history and that there has been no fiddling with the ECU,ie remaps etc.
    I think that this is a load of poop and they are trying it on. Today all they did was cancel the light and kept me hanging around for 2 hours. I now have to go back tomorrow with all my service receipts for them to maybe give me another load of cow poop. My car only has had 2 services and one of them was with this dealer and the other was with MPG.
    Regular Member Avenged's Avatar
    Liverpool
    Hope they sort it for you Andy!
    keep us posted!
    How's youre exhust doing??
    May 2007
    WINSFORD
    Total waste of time and Arnod Clark hace proved yet again just what a good dealership they are, NOT.
    The service manager is a snake in the grass or should I say a Wee Worm in the grass and sneaks around this forum and then prints out all your details and uses it against you. Because of this little %$^&(*& actions my warranty is now void but it was going to run out in September anyway so MPG will now permantly look after my car and my wifes and fathers.
    He also says he is a member so BE WARNED as he is just here to stab you in the back
    wirral,merseyside
    sounds similar 2 the problem in having+i also have a thread up.most people seem to ptu it down to split boost pipes or vacuume sensor.i have cleaned egr valve+boost sensor+replaced a split hose but am to yet get out in my car to see if the problems still there.
    By Shadrack in forum Vectra C / Signum Troubleshooting
  2. Replies: 17
    Last Post: 16th August 2012, 10:07
  3. Spanner Light and Engine Management Light
    By Paul_NI in forum Engine & Drivetrain
    Last Post: 8th August 2011, 13:42
  4. EGR Valve, Engine Management Light & Spanner Light
    By guygreen in forum Engine & Drivetrain
    Last Post: 12th December 2010, 20:09
  5. No throttle, traction control light, engine management light
    By si260188 in forum Engine & Drivetrain
    Last Post: 9th May 2010, 21:45
