Thread: Help
    Glasgow
    Angry Help
    Car keeps cutting out, can be matter of seconds or 10 to 15 min. Spanner light appears soon after start up and stays on until engine cuts out. Let car sit for a few minutes and then it will restart again but cut out again soon afterwards. New fuel pump fitted last month although symptoms are completely different. The car is a 55 plate 2.2 direct with 47k on the clock.
    Cant be without a car so any advice/help will be appreciated.
    May 2007
    Doing stuff
    It sounds like the fuel pressure regulator.
    Glasgow
    Smile Help
    Hi smithi thanks for the reply, begining to think that myself after much research. Can you tell me where its located and its cost.
    11 Post(s)
    Quote Originally Posted by dougiemc View Post
    You need to get the fault code(s) read out. Guesswork can become an expensive hobby if you start changing parts that aren't causing the problem.
    Glasgow
    Fault code is p1911 (fuel pump) according to the dealer but as i said this was only changed 4 weeks ago
    Devon
    75 Post(s)
    Vehicle : insignia
    Trim : irmscher
    Isnt that code P1911 VFS B Pressure Output Failed Low and if fuel pump is ok i assume next step would be to replace fuel pressure regulator
    Glasgow
    Any one know where the pressure regulator sits????
