Thread: A/C Not working
    Winteringham
    Default A/C Not working
    I have Climate control on my vectra Elite and it has been great until the other week, when I use it now All I get now is warm air not cold coming out,
    Took car to local quick fit yesterday who checked temp be for recharging, they checked for leaks none found they then recharged A/C and tested again it was still the same A/C is fully charged at no cost because made no difference,
    Has anybody got any idea's cant really afford a big bill needing to get car serviced and cam belt changed
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    Have you looked at the air flow flaps and actuators behind the heater console? Try removing the glovebox (5 screws and light disconnect) and then move the control dials and look for flap and actuator movement.
    Full Member spennny's Avatar
    Blantyre
    If your AC oil gets below a certain level a safety switch kicks in turns the AC of to prevent damage, have they reset this ?
    Surrey
    Going on from what Ste said, is it warm all the time i.e. when AC is turned off?
    Winteringham
    Quote Originally Posted by spennny View Post
    where do I check this?? have you got a photo
    Winteringham
    Quote Originally Posted by steve1975l View Post
    when driving car with A/C off can feel cold air coming in to car,
    Regular Member big_dave's Avatar
    Oct 2007
    Rochdale
    silly question. its not on economy mode is it?
    Admin plasma's Avatar
    On the Forum
    213 Post(s)
    Engine : 150
    Mileage : 74000
    Self resetting this, only activates on low pressure, when pressure high enoug then switch restores control back to car.
    Plasma's Tech2 services are now partially open and able to provide services
    Come Join our new forum Insignia Owners.com for all your Insignia chat and needs
    On the Forum
    213 Post(s)
    Engine : 150
    Mileage : 74000
    Sit in the car at idle, when you move temperature dial down from about 20 or so to Low you should hear/feel the compressor kick in.
    Also put the big button in centre of climate control and make sure the little box with says AC has got a tick in it.
    Winteringham
    A/C Now fixed for 55p
    It was one of the smal 10amp blade fuses that had blown, replased that and its is all working ok.
  1. radio working, not working, working again
    By J P S in forum Electrical & ICE (including SatNav)
    Last Post: 22nd February 2012, 00:59
  2. Replies: 4
    Last Post: 11th November 2011, 12:05
  3. Replies: 0
    Last Post: 10th November 2011, 22:58
  4. Working out MPG
    By justin32 in forum Vectra C / Signum Car Chat
    Last Post: 14th October 2011, 10:51
