Results 1 to 3 of 3
Thread: Washer bottle Sensor Position
    Regular Member redraptor_141's Avatar
    Sailing the High Seas on HMS Ark Royal
    Default Washer bottle Sensor Position
    Feel a bit stupid asking. but i thought i would just to be sure.im installing a GID so i thought i should get the sensor done at the same time. is there a template on the bottle for the hole i need to drill? also which way up do i fit it? is it with the white bit at the top or the white flappy bit at the bottom?ta guys, will
    It sits in sideways so that when the water level drops it flaps down and breaks the circuit mate... You can drill a hole for it wherever you like to be honest, dependn how low you want the fluid level to be before it comes on...
    If you're taking it out, you could always order the larger one which holds over 5 litres of fluid - the number is in the how2 for fitting headlight washers...
    Regular Member formby's Avatar
    paisley
    When I did mine I used a 20mm wood spade drill fits perfectly. there is a flat ridge near the bottom and to the right of the washer pump. so I measured up 12mm from this and found there was a mark on the bottle (wether this was an intended mark or coincidental I don't know)
    the flat bit of the sensor should be in line with this to keep it in the right orientation so that the float operates in the right direction.
    hope this helps
  1. My washer bottle has no sensor!!
    Last Post: 27th October 2013, 20:21
  2. For Sale: Washer Bottle Level Sensor
    By Das in forum Parts for sale
    Last Post: 26th August 2011, 14:14
  3. washer bottle sensor
    By paulvectrac in forum Styling
    Last Post: 17th September 2010, 19:50
  4. washer bottle sensor
    By kpf1grandprix in forum Vectra C / Signum Car Chat
    Last Post: 2nd July 2008, 23:28
vectra c washer bottle sensor
vectra c washer bottle sensor orientation
