Thread: Advice on the best way to extend a sky cable
    dudley
    Default Advice on the best way to extend a sky cable
    Bought a new telly and have decided to put the telly on the other side of the room, only problem Sky cable is too short, I have bought some new cable, 15metres worth, and some connectors, now my sky signal has dropped to half and the pic quality worse then before, gold plated connectors aswell, can't use hdmi as have an old sky box so its scart only, think its having extended the wire thats caused my problems as it was fine when it was in one peice.,
    Now I have enough cable to run out the wall and up to the dish to make it one piece but how does it attach dish end...? anyone know
    Jun 2007
    Wirral
    Quote Originally Posted by olid2002 View Post
    Hi olid2002
    Just remove the F connector from the dish and take it from the cable and reattch to the new cable.
    Details here http://www.satcure.co.uk/tech/fconn.htm
    neilrj
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    I extended the dish to box cable in our old house by using 2 normal TV aerial plugs and a double female connector. Worked just fine. You have to make sure that there are absolutely NO shield wire fibres crossing over with the core solid copper wire.
    Newcastle under Lyme
    Maplins sell inline junctions which are like a double sided sky box connector
    WGAF#5
    you can also get f connector in line boosters then it should give you a slight db gain in the original signal as well
    hth
    Dez
    morecambe
    39 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    any way you can think will work mate i insall stuff like that 4 a livin use aireal plugs or even a choclate block it all works
  1. advice on runnin cable from boot pls
    Last Post: 29th March 2010, 12:11
  2. Possible to extend functions on a Eberspächer?
    By fikse in forum Electrical & ICE (including SatNav)
    Last Post: 30th July 2009, 21:11
  3. Should i extend my warranty
    Last Post: 14th January 2009, 09:29
  4. Network Q warranty - managed to extend it again!
    By Duncan in forum Vectra C / Signum Car Chat
    Last Post: 22nd February 2007, 21:01
