Thread: headlight fuse
    inverness
    Default headlight fuse
    hi what fuse number is the passengers side headlight on a 2007 1.9cdti ? think mine has blown but cant find the fuse?????????????????
    Administrator plasma's Avatar
    On the Forum
    398 Post(s)
    Engine : 150
    Mileage : 74000
    Theres not a fuse for it, it comes straight from the UEC and I cant see any fuses specifically for it.
    FE23 and FE24 power the UEC, so you could check them. What makes you think its a fuse out?
    inverness
    cause the passesgers side bulb aint working now. it did work but then it went out. tried another bulb and still nothing
    inverness
    any other ideas? fuses are fine?
    inverness
    if it has tripped the uec would that throw up a fault code? could it be reset by opcom?
    inverness
    inverness
    inverness
    confused
    someone must know? has it blown a relay? can it be reset? come on!
    11 Post(s)
    Please be a bit more patient. If someone knows, then I'm *sure* they'll be along at some point.
    Bumping up your post every ½ to 1 hour won't do you any favours. It'll more likely get you ignored.
    Regular Member kenp's Avatar
    Kr. Hyllinge, Denmark
    Engine : 2.2 Direct
    try and look at fuse FE8.. but that also operates the other side of lights...
  1. Headlight adjustment fuse ?
    Last Post: 9th June 2010, 18:07
  2. Headlight Fuse
    By TopRod in forum Electrical & ICE (including SatNav)
    Last Post: 9th January 2010, 16:55
  3. Headlight washer system fuse keeps blowing
    By Matty H in forum Vectra C / Signum Car Chat
    Last Post: 10th January 2009, 19:58
  4. headlight fuse ?????
    By deano1 in forum Vectra C / Signum Car Chat
    Last Post: 29th October 2008, 18:42
  5. Headlight bulb fuse wattage?
    Last Post: 30th July 2007, 16:48
