Thread: itv hd
    Regular Member adfrodsham's Avatar
    lincoln
    Default itv hd
    remember seeing how to do this in a thread recently, and carnt seem to find it, any one know how?
    Regular Member solorider's Avatar
    swindon
    Quote Originally Posted by adfrodsham View Post
    if you mean on sky then sky say they dont do htv hd
    lincoln
    Quote Originally Posted by solorider View Post
    there is a way to manually programe itv hd
    Regular Member fingers66's Avatar
    Carpe Diem
    Try this, but all I get is ITV HD is currently unavailable
    Press TV Guide
    Go to Options then press select
    Go To Add Channels Tab
    Press select and enter the following numbers 11.427, H, 27.5, 2/3,
    Then press yellow button,
    The sky should do a scan, then come up with 8 channels
    The channel marked 10510 is ITV HD
    You then highlight it and press yellow button to " Tick " / store it
    Once done press select x 2 and then move to the left to the " Other Channels " tab abd go in there and press select, this is where you will find your manually added channels.
    swindon
    http://www.techwatch.co.uk/2009/03/1...hrough-sky-hd/
    it will only work on the new sky menu
    lincoln
    yeah, im getting unavailable also, cheers any way
    lincoln
    got my new card today and this works now
    Regular Member LJ sxi-nav's Avatar
    Winchester
    ITV HD only broadcast certain programmes at certain times (on freesat its a red-button option when available), it is possible that you tried it when there was no HD broadcast from ITV.
    I've got a newer samsung sky HD box, and I'm still waiting for my new EPG and new card
    I want to get ITV added to my HD lineup.
    Lancashire
    Vehicle : Vectra SRi
    Trim : XP NAV
    Engine : 1.9 CDTi 150
    Watched the cup final on ITV HD on my Sky+HD box, the instructions above are what I used.
