Thread: Brake banjo sizes
    Regular Member installer's Avatar
    Nottingham
    Default Brake banjo sizes
    So as I have read on here ,goodridge do braided hoses ,which are a recommened addition to doing the 314 upgrade.However there appears to be an issue with the rear banjo size on the vec c.
    Goodridge issue 10mm when 12mm rear banjo is required.
    Is this correct that on a 2005 model estate that a 12mm rear banjo is required?
    The front is 12mm also?
    Phoned LMF and they don`t do them any more,so went direct to goodridge and they still issue 10mm rear banjo`s.They`ll change it on the order but I need to state the size required for front and rear.I don`t really want to dismantle my brakes to find the size and the hoses come as a kit ,so don`t want spare rear hoses.Also want to do it in one go rather than faffing about.
    My fronts were fine for the kit, but yes the rears were too small. Mine's an 05 plate 1.9 CDTi so I would imagine yours would be the same mate...
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    I had the same prob on my 53 plate dti. Rear banjos were too little
    Nottingham
    Ok thanks ,peeps 12mm it would be appear to be.
    Oct 2006
    southampton
    15 Post(s)
    were there any with a rear banjo of 10mm or did they just make the kit wrong,
    Oct 2006
    southampton
    15 Post(s)
    could someone please post up some close-up piccies of the goodridge brake hoses fitted front and back, just need to have a look for reference. cheers
  1. brake sizes
    By DAVIDD88 in forum Suspension, Wheels & Brakes
    Last Post: 27th August 2011, 21:44
  2. Brake sizes - 3.0 V6 CDTI
    By Allblackdup in forum Suspension, Wheels & Brakes
    Last Post: 28th January 2010, 22:52
  3. rear brake pads? sizes
    By m3ath3ad in forum Handling & Braking
    Last Post: 21st June 2009, 19:50
  4. Help!! What brake sizes do I have?
    By martinbruce in forum Handling & Braking
    Last Post: 10th June 2009, 15:02
  5. Brake sizes
    By s1nglef1sh in forum Handling & Braking
    Last Post: 7th January 2009, 13:00
