Page 1 of 4 123 ... LastLast
Results 1 to 10 of 31
Thread: front bumper removal
    Edinburgh
    Default front bumper removal
    Tried to remove my front bumper as per How 2 so I could remove the chrome V for colourcoding. Discovered that the passenger side of the bumper appears to be glued into the clips. I guess it's had some front end damage before I owned it.
    The downside is I can't get the front bumper off without wrecking it and so far I've been unsuccessful at trying to remove the chrome V with the bumper on.
    I take it it's not really a good idea to try and colour code it with it in place especially since I don't have a garage. GRRRRR
    Newcastle under Lyme
    bummer. Just be wary that at some point you may need to remove the bumper if you have to change a bulb
    Edinburgh
    crap, I never thought of that. guess I better start saving my pennies for a new bumper
    Full Member spennny's Avatar
    Blantyre
    What part are you stuck at mate ?
    2 screws in each wheel arch
    4 screws/plastic things holding bumper to underside of car
    4 torx bolts along the top
    Where is the glue your mentioning
    Edinburgh
    I took off the 3 screws under each arch and then took the plastic rivet things off from underneath the car. I then pulled the bumper off the clip at the drivers side (at the wheel arch) and then went to do it at the passenger side. It won't come off at the passenger side and I can see some sort of adhesive in there, it seems to be all along the panel gap from the headlight to the wheel arch
    Blantyre
    Can you not get a sharp knife behind it and cut through it ?
    Wales, UK
    Wow, you actually have to remove the bumper for that !!!
    Blantyre
    Quote Originally Posted by mark_647 View Post
    Do you mean to change a bulb, its easier
    Edinburgh
    Quote Originally Posted by spennny View Post
    I haven't tried yet. I was so annoyed and also worried about damaging the bumper and/or paintwork. I'm guessing there is probably glue behind it too actually in the clip that the bumper goes into.
    Blantyre
    Quote Originally Posted by knoxvillain View Post
    I cant remember seeing a clip behind the bumper mate tbh, rear ones yes, But not on the front
    I have had mine and others of so many times,
  1. replaced Rad without removal of front bumper
    By dcm23251981 in forum Vectra C / Signum Car Chat
    Last Post: 5th March 2012, 14:25
  2. Front bumper removal
    By MickAP in forum Vectra C / Signum Car Chat
    Last Post: 12th March 2011, 15:36
  3. Front bumper removal
    By Steven T Davies-Moss in forum Styling
    Last Post: 1st January 2009, 20:49
  4. Front bumper skirt removal.
    By tallica371 in forum Bodywork & Interior
    Last Post: 6th October 2007, 21:35
  5. Front Bumper Removal Help
    By Bethan39 in forum Vectra C / Signum Car Chat
    Last Post: 30th July 2005, 14:52
vectra c front bumper removal
vauxhall vectra c front bumper removal
