Thread: alrm was going off I turned the key and there was smoke from the bonnet?
    South
    Default alrm was going off I turned the key and there was smoke from the bonnet?
    First post - Hello all,
    I have just bought a 51 plate 2.2 sri 150.
    As the title says I locked the doors using the remote lock on the keys, when I came back to the car I put the key in the door and opened it, the alarm started, I put the keys in the ignition, turned them untill the engine started and there was a loud pop type sound then loads of smoke came out of the far left hand side of the bonnet (around where the lights are).
    Now there is an engine fault sign on the dash and the alarm dosent work.
    Any ideas? was it a fuse or the alarm burning? I am new to vectras and havent got a clue really.
    Any help would be apreciated.
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    Have you opened the bonnet and taken a look - a bit of a clue would be needed here in order to give any useful advice, or we are truly guessing.
    South
    Everything looks fine, I cant see where the smoke came from.
    Regular Member dominic32's Avatar
    Oct 2007
    whitstable
    did it back fire when you started it?
    Ex-Staff Full Member Taffyopel's Avatar
    Oct 2007
    Horley, Surrey
    Sounds like your battery has exploded or your starter motor is knackered.
    There is a fuse box down by the front left under the bonnet. Open it up and check the fuses and wires.
    Snowman, you got your ears on?
    Surrey
    My money is on the battery too hence the alarm going off.
    Quote Originally Posted by mycosri View Post
    The alarm power sounder on the Vec-B is in the nearside wheel arch behind the plastic splash liner. That's where I'll put my money on where the smoke was coming from.
  1. Replies: 18
    Last Post: 20th November 2012, 21:41
  2. oil smoke from under my bonnet.
    By TimTay in forum Engine & Drivetrain
    Last Post: 18th July 2011, 20:37
  3. Look what turned up!
    By parsco in forum Styling
    Last Post: 28th January 2009, 19:35
  4. Smoke under Bonnet after Glow Plug Change
    By vec1975 in forum Engine & Drivetrain
    Last Post: 7th May 2008, 08:25
  5. 3.2 GSi - smoke under bonnet, BEWARE !!
    By gtr1000 in forum Engine & Drivetrain
    Last Post: 3rd February 2008, 00:53
