Thread: VX 2003 2.0DTi Juddering
    Apr 2006
    Kingswinford
    Trim : LS
    Engine : 2.0 DTI
    Mileage : 150000
    Default VX 2003 2.0DTi Juddering
    At around 1700 revs the you can feel the car start to judder, ever so slightly, but I can notice it. Acceleration is fine. Its just when I at 1700 - 2000 revs.
    Any ideas ???
    May 2006
    Nottingham
    All the time?
    My old one used to do this from time to time...a bit like a flat spot? I just put up with it.
    A
    Nicking Ya Dinner.
    Possible engine mount gone soft/split.
    Try to be sure whether its engine or not though, my old Omega had an issue when I hit 25mph, it felt like an unbalanced wheel, but it wasn't, I still dont know what it was exactly, but I didn't want to spend spend spend finding it, the fact it was second hand when I bought it meant I had no idea of what had been done to the car before I had it, the things I suspected were wheel bearing/suspension parts, but the guy who inspects the car for the council would have found anything amiss there, so I then began to suspect an unbalanced prop,gearbox or crankshaft, or once again it could have been a mount.
    Regular Member Ian's Avatar
    York
    my astra coupe turbo does this on cheap petrol under light acceleration, give the throttle a bit more and its fine. I put SUL in it now no probs. Perhaps if you try a different brand of diesel it may help - pretty cheap to try too (you'll use the diesel if you see what I mean)
    Belfast
    As in the other thread, avoid cheap supermarket diesel. Mine does it on Tesco diesel, but not on biodiesel or on Texaco standard diesel.
    Apr 2006
    Kingswinford
    Trim : LS
    Engine : 2.0 DTI
    Mileage : 150000
    Latest update. I've always used either BP or Esso for fuel and I've had the front tyres checked and theres nowt wrong there. Is there anything I as a layman can check ???
    Many thanks for your assistance
    Apr 2006
    Kingswinford
    Trim : LS
    Engine : 2.0 DTI
    Mileage : 150000
    All sorted, had all four wheels balanced and all is fine now
    Now in Girvan Scotland
    try the acetone treatment worked on my 2.2dti and gave me a pleasureable boost !
    you will need to treat it to a K&N panel filter as well, and remove the insert shown in the "How To" pages.
  1. vectra 2.0DTI 2003 REMAP
    By yadziyad in forum Diesel Engine related
    Last Post: 22nd May 2011, 09:06
  2. Mis firing 2003 vectra 2.0dti
    By dezzypoole in forum Engine & Drivetrain
    Last Post: 11th February 2011, 00:29
  3. will vxr springs fit my 2003 2.0dti
    By delberto in forum Handling & Braking
    Last Post: 14th December 2009, 14:02
  4. 2003 2.0dti 8v fails to Start
    By Neil.b in forum Engine & Drivetrain
    Last Post: 6th January 2009, 21:02
  5. what speakers for a 2003 2.0dti LS???
    By stubopvectra in forum Electrical & ICE (including SatNav)
    Last Post: 29th March 2008, 15:28
