Results 1 to 10 of 19
Thread: Hi All- NEED HELP WITH a Signum INDICATOR FAULT PLS
    North London
    Default Hi All- NEED HELP WITH a Signum INDICATOR FAULT PLS
    I have a 2004 Vauxhall Signum where the OSR indicator has failed causing the display to indicate a fault. It's not the bulb or holder or fuses, I have tried replacing underbonnet, behind glove and rear body control modules swaopping with SH units and failed to fix! Fault code is Open Circuit to OSR Indicator. The indicator tends to work when first powered for a few flashes then fails.Does the rear module have to be programmed to the existing system? Any help would be greatly appreciated as I'm at my wits end
    Full Member Teamtom's Avatar
    Vehicle : Vectra C Hatch
    Trim : SRI
    Engine : 1.8 VVT
    Mileage : 53000
    You say the fault is sporadic and is an open circuit. I'd be more inclinded to investigate the indicator stalk istelf.
    Rubbin'z racing Harry!
    Regular Member rushy's Avatar
    Vehicle : SRi
    Engine : Z22SE (2.2 Petrol)
    Mileage : 137000
    Quote Originally Posted by Teamtom View Post
    The stalk can't be removed on its own, its integrated with the CIM module (a £350 fix) I'm not saying it is the CIM but it controls all dials, immobiliser and indicator functions amongst other things.
    Administrator plasma's Avatar
    On the Forum
    359 Post(s)
    Engine : 150
    Mileage : 74000
    if the front one works fine then its not the CIM, could be chaffed wiring from the REC through to the bulb cluster. If your still stuck come down to Brentwood 13th - 14th June, and we'll strip it out and trace the problem, (check the link in my signature)
    Trim : SRI
    Engine : 1.8 VVT
    Mileage : 53000
    woah! not aware of that. What a rubbish idea!!!! anyway, such is life.
    Looks like it may be the job for a stealer unless you can find any faults with wiring.
    .check earth point near the rear light clusters. Also check that all pins in multi-plugs look ok etc etc.
    Vehicle : SRi
    Mileage : 137000
    Forget the dealer, take Deans offer up, he know his stuff when it comes to the Vecs electronics.
    Quote Originally Posted by plasma View Post
    birmingham
    Vehicle : Vectra gsi
    Trim : Full heated leather
    Engine : 3200
    welcome
    Plymouth
    after what ive heard about Plasma.... he can work on my car anytime!!
    Mileage : 000
    Dean is a Top bloke. Take it from me.
    Regular Member John C S's Avatar
    May 2007
    Gangsta crossover on the drive? Check
    Quote Originally Posted by Diet1985 View Post
    Sounds like a line from the film Top Gun.
    " Kazansky, you are still dangerous, You can be my Wing Man anytime"
  1. Indicator Fault
    By philc1210 in forum Electrical & ICE (including SatNav)
    Last Post: 15th February 2013, 23:50
  2. Indicator intermitant fault
    By Photog Dave in forum Electrical & ICE (including SatNav)
    Last Post: 31st March 2011, 22:51
  3. Indicator fault
    By TopRod in forum Electrical & ICE (including SatNav)
    Last Post: 12th November 2010, 16:29
  4. Fault indicator.
    By Saxman in forum Vectra C / Signum Car Chat
    Last Post: 6th April 2010, 20:42
  5. Indicator fault
    By Sp33dy in forum Electrical & ICE (including SatNav)
    Last Post: 23rd March 2010, 03:34
tablet okanac
