Results 1 to 10 of 13
Thread: hi speed boost problem
    wirral,merseyside
    Default hi speed boost problem
    bit of a strange one this so would apretiate any help
    car is a 2.2 dti sri 2002 plate
    cars fine at low speed whilst boosting around the streets but when i get on to the motorway high speed+try to put my foot down the spanner light comes on+it goes in to limb mode.
    it seems to be if you hold the revs then try to use the boost to pull off/overtake.
    im new to this car so im not properly up on them.i have done some research on here+found split pipes are a common fault so found a split in a boost pipe going to the vacuume actuator+replaced the said pipe but it is no beter??
    HELP!!!
    wirral,merseyside
    any body got any info on this 1,ive read all the pages+links off doing a search+ive cleaned the boost sensor.my next port of call i think is going to be the vacuume actuator+c how that goes??
    South Wales Assistant Regional Organiser davidjameswest's Avatar
    llantwit major
    i had this a few weeks ago mate turned car off then back on and was fine but would love to know why it happend
    wirral,merseyside
    yes mate that works turning the car off+back on for me aswell but then just hapens again when i get back on motorway
    its a strange one
    llantwit major
    i did have my foot flat to the floor when it happend but only at speed but like you dont get any thing like iot when i boot it through the gears
    wirral,merseyside
    sounds exactly the same as my problem mate it never hapens driving round streets it seems to be at a certain speed+as you said foot to the floor,overtaking or so on
    llantwit major
    yea god know what it is , i have cleaned the egr , boost sensor and the actuator, got problem with a clunkin from the rear now after changin the disc and pads
    Regular Member Celes's Avatar
    Slovenia, Koper
    Vehicle : Opel Signum
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    Had something similar on our 2.2DTi Auto. It had a split hose going from intercooler to turbo. It was a 3cm crack!
    llantwit major
    but why it happen only in higher gears and not when revved high round town for example
    Slovenia, Koper
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    Hmm...could it be that in higher gears (on motorway) it is on higher revs for longer? Maybe something's wrong with the vacum sistem?
    The 2.2DTi we have did go into limp on high speed runs but not in town. A tiny vacum hose was damaged or something. A couple of days before the repair it was doing it all the time and everywhere, low or high up the rev range....
  1. boost problem
    By hicksy in forum Engine & Drivetrain
    Last Post: 1st March 2013, 07:41
  2. Boost problem Z20net
    By blue estate in forum Engine & Drivetrain
    Last Post: 30th June 2011, 15:16
  3. Boost sensor problem?
    By darrenmac in forum Engine & Drivetrain
    Last Post: 23rd April 2010, 09:55
  4. Boost Pressure Problem
    By CristianTM in forum Engine & Drivetrain
    Last Post: 27th September 2009, 20:53
  5. 19 cdti boost problem
    By sri22dti in forum Engine & Drivetrain
    Last Post: 7th February 2009, 23:08
