Thread: Lift off stutter - 1.9cdti 150
    Malton
    Default Lift off stutter - 1.9cdti 150
    I have a new problem on the Vectra, when your driving at say a constant speed on the motorway, just feathering the throttle, if you slightly lift it'll stutter.
    I've tried it in cruise control and it does it a lot less, but will still do it say at the top of a hill/brow, I guess where the c/c is lifting off too?
    Any ideas?
    G
    Malton
    No one?
    Glasgow
    Only a guess how about the rubber hoses going into the turbo have they perished ?
    preston
    Smile
    hmmmm
    initially clean egr ( and boost sensor / maf sensor while you're at it )
    this should cover some of common running issues .
    no joy then get back to us
    Lancashire
    Vehicle : Vectra SRi
    Trim : XP1
    Engine : 1.9 CDTi 150
    Mileage : 66000
    Sounds EGR related, could be starting to stick.
    Farnborough, Hampshire
    Hi
    Had identical problem (accompanied by the car/spanner light for 3 mins at cold startup which i now believe is unrelated)
    I did the following:
    Clean EGR
    Clean Boost sensor
    Changed boost pipes
    Did the air box mod and changed the filter
    Changed the fuel filter and cleaned the housing
    All of these took a couple of hours and cost me the best part of £25 including both filters, hoses and carb cleaner (used my other halfs tooth brush for cleaning the EGR and boost sensor)
    The problem has all but gone away, its ever so sligtly there at really low revs but one of some of those things definitely made a massive difference
    Regular Member Gazza36's Avatar
    Jan 2010
    Cornwall
    Sounds like egr
  1. A stutter at about 1800 RPM
    By Ginge7289 in forum Engine & Drivetrain
    Last Post: 2nd May 2011, 09:03
  2. 1.9cdti 120 estate eng stutter limp mode
    By blackadder62 in forum Engine & Drivetrain
    Last Post: 7th February 2011, 14:53
  3. question for 1.9cdti 120 pre face lift owners
    By john1 in forum Vectra C / Signum Car Chat
    Last Post: 25th January 2010, 22:09
  4. 4,000 rpm engine stutter
    By djhepburn in forum Engine & Drivetrain
    Last Post: 28th February 2008, 21:48
  5. 2nd service 2005 face lift 1.9cdti
    By fields in forum Vectra C / Signum Car Chat
    Last Post: 12th October 2007, 15:23
