Page 1 of 5 123 ... LastLast
Results 1 to 10 of 41
Thread: Diesel Particulate Filter 1.9CDTI temp/permanent fix
    Regular Member Drew's Avatar
    Sedgefield
    Default Diesel Particulate Filter 1.9CDTI temp/permanent fix
    Had problems with mine completely blocking. £1200 to replace. Took it off, cut it open, knocked insisdes out, welded up and replaced. Car ran fine (better than ever) but spanner light would not go out. Found pressure differential sensor mounted on bulk head below right of fuel filter assembly. Simply disconnect smaller rubber pipe (there are two pipes, one bigger diameter than the other) and crimp it to stop any gas escaping (I folded it back on itself and used a cable tie) reset the spanner light and this time it stays off. Car shows no faults. Local garage says will still pass emmisions as most vectras didn't have them anyway.
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    It will likely pass, as the diesel test is only a smoke test at high idle.
    Interesting that disconnecting the pipe effectively fools the delta P sensor into registering enough pressure to 'detect' a non existant filter inside the can. Does the one you disconnected go to the filter outlet side?
    Sedgefield
    I think the thin one goes into the side near the front of the filter and the fat one to the rear but it's hard to tell which one is which now its back on the car, I can't get far enough underneath. I had tried combinations of both off and each one back on and found that this way works. I have done a few thousand miles now with no probs, the car has even gone through some DPF regenerations, loads of smoke as usual for a minute or so fortunately no flames!!!
    Quote Originally Posted by Drew View Post
    best not look for the flames m8 ...................
    Full Member Big Sig's Avatar
    Nice I do wonder what happens to the diesel it injects into the dpf chamber. Not sure if it could be told that the dpf never needs a regen via tech 2?
    Regular Member Avenged's Avatar
    Liverpool
    this thread intrest's me!!!
    I shall be watching this one!
    Regular Member Kcs's Avatar
    Feb 2007
    Tamworth
    Mmmmm ! the regen on mine is every 650 -700 miles, i did think there
    was some back pressure sensors to activate the regen, but yours
    should have no back pressure ! it must chuck the extra fuel
    through for old times ! Why did you remove it ? it should be fine as long
    as it cleans out when it should.
    Regular Member ghostrider's Avatar
    On another planet
    Vehicle : 2.0l CDTi Bi-Turbo Insginia Sports Tourer
    Trim : Vx Line Nav Sri
    Engine : 2.0
    Hmmm. Marking this thread to see the outcome. Sounds interesting
    Quote Originally Posted by Kcs View Post
    Feb 2007
    Tamworth
    Yep ! can see the wood now you have moved the trees ! !
  1. Diesel Particulate Filter
    By bafoo in forum Vectra C / Signum Car Chat
    Last Post: 13th January 2011, 18:06
  2. Diesel Particulate Filter Re-gen
    By RobertHayman in forum Engine & Drivetrain
    Last Post: 16th November 2010, 23:47
  3. Diesel Particulate Filter or not??
    By Drew in forum Engine & Drivetrain
    Last Post: 26th January 2009, 09:32
  4. Diesel Particulate Filter
    By Eddie Dee in forum Vectra C / Signum Car Chat
    Last Post: 20th March 2007, 20:10
  5. Diesel Particulate Filter
    By VectraV6CDTi in forum Vectra C / Signum Car Chat
    Last Post: 6th October 2006, 09:16
1.9 cdti dpf filter
vectra c dpf filter cleaning
DPF for Vectra C 1.9
vectra c 1.9 cdti particulate filter
vectra c 1.9cdti dpf cleaning
vectra c dpf
cleaning a vauxhall signum dpf
1.9 cdti completely blocked dpf
vectra dpf
how to clean the particulate filter on a vauxhall signum
diesel particulate filter vectra c
dpf vauxhall vectra
vectra cdti dpf replacement
how to clean a gas particle filter on a maverick
replacing a vectra dpf
vectra c sri cdti how to clean dpf
vectra c 1.9 cdti diesel particulate filter
vauxhall signum 1.9cdti cuts out at certain temperature
